주요 콘텐츠로 건너뛰기
HP Photosmart Premium C309g Printhead Replacement
  1. HP Photosmart Premium C309g Printhead Replacement, Printhead: 1 단계, 이미지 1/1
    • Open the top of the printer as shown.
    • Locate the ink cartridges housed by the printhead.
  2. HP Photosmart Premium C309g Printhead Replacement: 2 단계, 이미지 1/2 HP Photosmart Premium C309g Printhead Replacement: 2 단계, 이미지 2/2
    • Remove each ink cartridge by pushing the tab and lifting the cartridge.
    • Set all 5 cartridges aside.
  3. HP Photosmart Premium C309g Printhead Replacement: 3 단계, 이미지 1/3 HP Photosmart Premium C309g Printhead Replacement: 3 단계, 이미지 2/3 HP Photosmart Premium C309g Printhead Replacement: 3 단계, 이미지 3/3
    • Lift the lever located on the right side of the printhead.
  4. HP Photosmart Premium C309g Printhead Replacement: 4 단계, 이미지 1/2 HP Photosmart Premium C309g Printhead Replacement: 4 단계, 이미지 2/2
    • Lift the printhead and remove it.
결론
다른 10명이 해당 안내서를 완성하였습니다.
Laura
회원 가입일: 10/23/14
694 평판
안내서 3개 작성하였습니다
Michigan Tech, Team 1-2, Lauer Fall 2014 Michigan Tech, Team 1-2, Lauer Fall 2014 회원
MTU-LAUER-F14S1G2
3 회원들
안내서 5개 작성하였습니다
댓글 한 개
Greetings:
I just replaced an empty black ink cartridge. The colors all print, but the new cartridge does not print. I have touched the cartridge and the ink seems wet and okay. Any other thoughts? I have taken the cartridge out and re-inserted it numerous times to no avail.
Thank you for any help you can give me.
Louann Dicus
dicus_6216 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 5,471
