주요 콘텐츠로 건너뛰기
HP Photosmart Premium C309g Scanner Glass Replacement
필요한 것
  1. HP Photosmart Premium C309g Scanner Glass  Replacement, Scanner Glass: 1 단계, 이미지 1/1
    • Open the top of the printer. The printer should appear as shown.
  2. HP Photosmart Premium C309g Scanner Glass  Replacement: 2 단계, 이미지 1/2 HP Photosmart Premium C309g Scanner Glass  Replacement: 2 단계, 이미지 2/2
    • Use the blue plastic opening tool to pry the trim pieces all the way around the printer.
    • Loosen the pieces around the edges before pulling to remove from the printer.
    • Pull the (4) trim pieces off and set them aside.
  3. HP Photosmart Premium C309g Scanner Glass  Replacement: 3 단계, 이미지 1/2 HP Photosmart Premium C309g Scanner Glass  Replacement: 3 단계, 이미지 2/2
    • Using the blue plastic opening tool, pull from the middle and then slide back to remove the side panels.
    • The side trim pieces need to be removed before the front trim pieces.
  4. HP Photosmart Premium C309g Scanner Glass  Replacement: 4 단계, 이미지 1/1
    • Using the T9 Torx Security screwdriver bit, unscrew the five 12mm screws shown.
  5. HP Photosmart Premium C309g Scanner Glass  Replacement: 5 단계, 이미지 1/1
    • The scanner flap is attached by a clip that can be dislodged by pulling it gently away from the printer.
    • Keeping the scanner flap upright, slide it toward the unattached clip in order to dislodge the second clip.
    • Both clips will come unattached and you can set the scanner flap aside.
  6. HP Photosmart Premium C309g Scanner Glass  Replacement: 6 단계, 이미지 1/1
    • Lift the scanner glass piece from the printer.
  7. HP Photosmart Premium C309g Scanner Glass  Replacement: 7 단계, 이미지 1/2 HP Photosmart Premium C309g Scanner Glass  Replacement: 7 단계, 이미지 2/2
    • The scanner glass is attached to the plastic piece with adhesive tape.
    • Pull off the glass and re-set new piece of glass.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Laura
회원 가입일: 10/23/14
694 평판
안내서 3개 작성하였습니다
Michigan Tech, Team 1-2, Lauer Fall 2014 Michigan Tech, Team 1-2, Lauer Fall 2014 회원
MTU-LAUER-F14S1G2
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 755
