주요 콘텐츠로 건너뛰기
HP Photosmart Premium C309g Wireless Card Replacement
필요한 것
  1. HP Photosmart Premium C309g Wireless Card Replacement, Wireless Card: 1 단계, 이미지 1/1
    • Open the top of the printer as shown.
    • The wireless card is located on the left side of the printer if you are viewing it from the front.
  2. HP Photosmart Premium C309g Wireless Card Replacement: 2 단계, 이미지 1/1
    • Using the T9 Torx Security screwdriver bit, unscrew the 12 mm screw on the far left side on the top of the printer.
  3. HP Photosmart Premium C309g Wireless Card Replacement: 3 단계, 이미지 1/1
    • After unscrewing the screw, the left side will slide down revealing the wireless card.
  4. HP Photosmart Premium C309g Wireless Card Replacement: 4 단계, 이미지 1/3 HP Photosmart Premium C309g Wireless Card Replacement: 4 단계, 이미지 2/3 HP Photosmart Premium C309g Wireless Card Replacement: 4 단계, 이미지 3/3
    • Unscrew one 12mm screw and gently disconnect the wireless card from the motherboard.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Charles
회원 가입일: 10/23/14
371 평판
안내서 2개 작성하였습니다
Michigan Tech, Team 1-2, Lauer Fall 2014 Michigan Tech, Team 1-2, Lauer Fall 2014 회원
MTU-LAUER-F14S1G2
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 1,552
