필요한 것
Rotate the printer 90 degrees counter clockwise so that the side panel next to control panel is facing you.
Remove the two T10 12mm Torx screws from the left side panel.
Set aside the printer body.
Remove the three T10 12 mm Torx screws from the back of control panel circuit board.
거의 끝나갑니다!
결론
다른 4명이 해당 안내서를 완성하였습니다.
