주요 콘텐츠로 건너뛰기
HP Photosmart c3180 Scanner Glass Replacement
필요한 것
  1. HP Photosmart c3180 Scanner Glass Replacement, Top Panel of HP Photosmart c3180 printer: 1 단계, 이미지 1/2 HP Photosmart c3180 Scanner Glass Replacement, Top Panel of HP Photosmart c3180 printer: 1 단계, 이미지 2/2
    • Before disassembling your printer, be sure that the printer has been unplugged to avoid any risk of injury.
    • Rotate the printer 90 degrees counter clockwise so that the side panel next to control panel is facing you.
    • Remove the two T10 12mm Torx screws from the left side panel.
  2. HP Photosmart c3180 Scanner Glass Replacement: 2 단계, 이미지 1/2 HP Photosmart c3180 Scanner Glass Replacement: 2 단계, 이미지 2/2
    • Firmly pull the the back of the side panel until it separates from the body of the printer.
    • Rotate the side panel upwards while pulling it towards yourself to remove the panel.
  3. HP Photosmart c3180 Scanner Glass Replacement: 3 단계, 이미지 1/2 HP Photosmart c3180 Scanner Glass Replacement: 3 단계, 이미지 2/2
    • Rotate the printer 90 degrees clockwise.
    • Grasp the paper tray and rotate it down.
    • Insert your fingers into the slot in the printer door and pull to rotate the gate down.
  4. HP Photosmart c3180 Scanner Glass Replacement: 4 단계, 이미지 1/2 HP Photosmart c3180 Scanner Glass Replacement: 4 단계, 이미지 2/2
    • Remove the two T10 12 mm Torx screws.
    • Grasp both sides of the side panel and pull it forward to remove the panel.
  5. HP Photosmart c3180 Scanner Glass Replacement: 5 단계, 이미지 1/2 HP Photosmart c3180 Scanner Glass Replacement: 5 단계, 이미지 2/2
    • Rotate the printer 90 degrees counter clockwise.
    • Lift the scanner lid to expose the scanner glass.
  6. HP Photosmart c3180 Scanner Glass Replacement: 6 단계, 이미지 1/1
    • Do not attempt to lift the top panel off the printer yet because it is still connected to the printer body by a cable.
  7. HP Photosmart c3180 Scanner Glass Replacement: 7 단계, 이미지 1/2 HP Photosmart c3180 Scanner Glass Replacement: 7 단계, 이미지 2/2
    • Inside the printer is a small white tab. Press it inward with a spudger until a pop is heard.
    • Remove the front panel by grasping its front and pulling away from the printer.
    Änderung des Textes: die kleine Lasche verriegelt die kleine Frontblende: mit leichtem Druck Richtung “rechte Druckerseite entriegeln, gleichzeitig jene Blende nach vorn lösen.
    Garofalo - 답글
  8. HP Photosmart c3180 Scanner Glass Replacement: 8 단계, 이미지 1/2 HP Photosmart c3180 Scanner Glass Replacement: 8 단계, 이미지 2/2
    • Remove the cable connecting the top panel of the printer to the power button assembly.
  9. HP Photosmart c3180 Scanner Glass Replacement: 9 단계, 이미지 1/1
    • Carefully lift the top panel of the printer away from the printer body.
    nur die dünne weiße Abdeckung, die graue bleibt noch; zuerst hinten anheben, vorn ist mittig eine Nase zu lösen.
    Garofalo - 답글
  10. HP Photosmart c3180 Scanner Glass Replacement, Scanner Glass: 10 단계, 이미지 1/2 HP Photosmart c3180 Scanner Glass Replacement, Scanner Glass: 10 단계, 이미지 2/2
    • Set aside the printer body.
    • Unscrew the T10 12 mm Torx screw.
    • Remove the plastic tab holding the glass in place.
    • Carefully lift the scanner glass panel above the plastic barrier and pull it towards the control panel circuitry. It can take quite a bit of force to get the panel to slide out. If not removed carefully, the scanner glass can shatter
  11. HP Photosmart c3180 Scanner Glass Replacement: 11 단계, 이미지 1/2 HP Photosmart c3180 Scanner Glass Replacement: 11 단계, 이미지 2/2
    • Slide the new panel of glass in to the tabs on the right side of the top panel.
    • Place your thumb on top of the tab at the top of the panel. grip the outside edge of the panel and roll outward, allowing the scanner glass panel to fall into place.
  12. HP Photosmart c3180 Scanner Glass Replacement: 12 단계, 이미지 1/1
    • Reattach the plastic piece which holds the scanner glass down and the 2.74 mm Torx screw.
결론
To reassemble your device after replacing the glass, follow these instructions starting from the removal of the top panel in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
Jim
회원 가입일: 10/06/11
1,590 평판
안내서 10개 작성하였습니다
Cal Poly, Team 20-30, Maness Fall 2011 Cal Poly, Team 20-30, Maness Fall 2011 회원
CPSU-MANESS-F11S20G30
4 회원들
안내서 25개 작성하였습니다
댓글 한 개
If I hadn't already taken mine all the way apart to clean it up good this is all I needed to do to start off with. Good direction step by step. Thanks
ALVIN L MAULDIN - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 10
전체 시간: 3,532
