소개
After completing the Outer Shell Disassembly guide, this process will aid in replacing the HP Photosmart c4780 motherboard with minimal technical requirements.
필요한 것
Unplug the device from any energy sources.
Lift the top cover of the scanner.
Use a plastic opening tool to remove the plastic frame surrounding the glass.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
