주요 콘텐츠로 건너뛰기
HP Photosmart c4780 Motherboard Replacement
필요한 것
  1. HP Photosmart c4780 Motherboard Replacement, Outer Shell Disassembly: 1 단계, 이미지 1/2 HP Photosmart c4780 Motherboard Replacement, Outer Shell Disassembly: 1 단계, 이미지 2/2
    • Unplug the device from any energy sources.
    • Lift the top cover of the scanner.
    • Use a plastic opening tool to remove the plastic frame surrounding the glass.
  2. HP Photosmart c4780 Motherboard Replacement: 2 단계, 이미지 1/1
    • Carefully pull the frame away from the glass.
    • If it doesn't remove easily, use the iFixit Opening Tool again to pry stuck sections.
  3. HP Photosmart c4780 Motherboard Replacement: 3 단계, 이미지 1/1
    • Use a T10 screwdriver to unscrew the two screws that fasten the frame to the printer hood.
  4. HP Photosmart c4780 Motherboard Replacement: 4 단계, 이미지 1/2 HP Photosmart c4780 Motherboard Replacement: 4 단계, 이미지 2/2
    • Put your finger behind the panel with the power button.
    • Then, pull the piece outwards.
  5. HP Photosmart c4780 Motherboard Replacement: 5 단계, 이미지 1/2 HP Photosmart c4780 Motherboard Replacement: 5 단계, 이미지 2/2
    • Unscrew the screw inside the power button panel space.
    • Then, unscrew the screw that is across the printer slider.
  6. HP Photosmart c4780 Motherboard Replacement: 6 단계, 이미지 1/1
    • Pull the white circuit board outwards which is located under the small screen.
    • Unplug the small ribbon cable from the circuit board.
    • Be careful when you unplug the ribbon cable not to use too much force. Using too much force may damage or rip the cable.
    • Unplug the small ribbon cable from the circuit board. Be careful when you unplug the ribbon cable not to use too much force. Using too much force may damage or rip the cable.
  7. HP Photosmart c4780 Motherboard Replacement: 8 단계, 이미지 1/2 HP Photosmart c4780 Motherboard Replacement: 8 단계, 이미지 2/2
    • Pull the memory card reader's circuit board out.
    • Detach the white wiring connector from the back of the circuit board.
    • You may need to use a finger nail or a plastic opening tool to detach the white wiring connector from the circuit board.
  8. HP Photosmart c4780 Motherboard Replacement: 9 단계, 이미지 1/2 HP Photosmart c4780 Motherboard Replacement: 9 단계, 이미지 2/2
    • Put your finger behind the small screen.
    • Then, pull it up.
    • Do not hesitate to use force to remove the TouchSmart panel.
    • Disconnect the ribbon cable from the small screen.
  9. HP Photosmart c4780 Motherboard Replacement: 10 단계, 이미지 1/1
    • Pull the printer hood upward.
  10. HP Photosmart c4780 Motherboard Replacement, Motherboard: 11 단계, 이미지 1/1
    • Remove the three uncovered T10 screws from the motherboard.
  11. HP Photosmart c4780 Motherboard Replacement: 12 단계, 이미지 1/1
    • Gently remove the seven cables that are attached to the motherboard using a plastic opening tool.
  12. HP Photosmart c4780 Motherboard Replacement: 13 단계, 이미지 1/1
    • Gently lift motherboard out of the slot.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
garrett hall
회원 가입일: 09/26/12
49 평판
안내서 2개 작성하였습니다
Cal Poly, Team 2-11, Propen Fall 2012 Cal Poly, Team 2-11, Propen Fall 2012 회원
CPSU-PROPEN-F12S2G11
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 4,099
