주요 콘텐츠로 건너뛰기
HP Photosmart c4780 Scanner Glass Assembly Replacement
필요한 것
  1. HP Photosmart c4780 Scanner Glass Assembly Replacement, Outer Shell Disassembly: 1 단계, 이미지 1/2 HP Photosmart c4780 Scanner Glass Assembly Replacement, Outer Shell Disassembly: 1 단계, 이미지 2/2
    • Unplug the device from any energy sources.
    • Lift the top cover of the scanner.
    • Use a plastic opening tool to remove the plastic frame surrounding the glass.
  2. HP Photosmart c4780 Scanner Glass Assembly Replacement: 2 단계, 이미지 1/1
    • Carefully pull the frame away from the glass.
    • If it doesn't remove easily, use the iFixit Opening Tool again to pry stuck sections.
  3. HP Photosmart c4780 Scanner Glass Assembly Replacement: 3 단계, 이미지 1/1
    • Use a T10 screwdriver to unscrew the two screws that fasten the frame to the printer hood.
  4. HP Photosmart c4780 Scanner Glass Assembly Replacement: 4 단계, 이미지 1/2 HP Photosmart c4780 Scanner Glass Assembly Replacement: 4 단계, 이미지 2/2
    • Put your finger behind the panel with the power button.
    • Then, pull the piece outwards.
  5. HP Photosmart c4780 Scanner Glass Assembly Replacement: 5 단계, 이미지 1/2 HP Photosmart c4780 Scanner Glass Assembly Replacement: 5 단계, 이미지 2/2
    • Unscrew the screw inside the power button panel space.
    • Then, unscrew the screw that is across the printer slider.
  6. HP Photosmart c4780 Scanner Glass Assembly Replacement: 6 단계, 이미지 1/1
    • Pull the white circuit board outwards which is located under the small screen.
    • Unplug the small ribbon cable from the circuit board.
    • Be careful when you unplug the ribbon cable not to use too much force. Using too much force may damage or rip the cable.
    • Unplug the small ribbon cable from the circuit board. Be careful when you unplug the ribbon cable not to use too much force. Using too much force may damage or rip the cable.
  7. HP Photosmart c4780 Scanner Glass Assembly Replacement: 8 단계, 이미지 1/2 HP Photosmart c4780 Scanner Glass Assembly Replacement: 8 단계, 이미지 2/2
    • Pull the memory card reader's circuit board out.
    • Detach the white wiring connector from the back of the circuit board.
    • You may need to use a finger nail or a plastic opening tool to detach the white wiring connector from the circuit board.
  8. HP Photosmart c4780 Scanner Glass Assembly Replacement: 9 단계, 이미지 1/2 HP Photosmart c4780 Scanner Glass Assembly Replacement: 9 단계, 이미지 2/2
    • Put your finger behind the small screen.
    • Then, pull it up.
    • Do not hesitate to use force to remove the TouchSmart panel.
    • Disconnect the ribbon cable from the small screen.
  9. HP Photosmart c4780 Scanner Glass Assembly Replacement: 10 단계, 이미지 1/1
    • Pull the printer hood upward.
  10. HP Photosmart c4780 Scanner Glass Assembly Replacement, Scanner Glass Assembly: 11 단계, 이미지 1/2 HP Photosmart c4780 Scanner Glass Assembly Replacement, Scanner Glass Assembly: 11 단계, 이미지 2/2
    • Lift the scanning lid from the lower portion of the printer hood.
  11. HP Photosmart c4780 Scanner Glass Assembly Replacement: 12 단계, 이미지 1/2 HP Photosmart c4780 Scanner Glass Assembly Replacement: 12 단계, 이미지 2/2
    • Leaving the ribbon connected, lift the sliding scanner off the track.
    • Pull the ribbon cable out of the slot on the scanner circuit board.
    • Insert the scanning piece into the rolling track.
결론
To reassemble the sliding scan piece, follow these instructions in reverse order.
Renee Lamb
회원 가입일: 09/26/12
235 평판
안내서 3개 작성하였습니다
Cal Poly, Team 2-11, Propen Fall 2012 Cal Poly, Team 2-11, Propen Fall 2012 회원
CPSU-PROPEN-F12S2G11
4 회원들
안내서 6개 작성하였습니다
댓글 한 개
Where can i buy the scaning piece? Im from Spain.
Bogdan Cosmin - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 1,505
