주요 콘텐츠로 건너뛰기
HP Photosmart c4780 Scanner Glass Replacement
필요한 것
  1. HP Photosmart c4780 Scanner Glass Replacement, Outer Shell Disassembly: 1 단계, 이미지 2개 중 1개 HP Photosmart c4780 Scanner Glass Replacement, Outer Shell Disassembly: 1 단계, 이미지 2개 중 2개
    • Unplug the device from any energy sources.
    • Lift the top cover of the scanner.
    • Use a plastic opening tool to remove the plastic frame surrounding the glass.
  2. HP Photosmart c4780 Scanner Glass Replacement: 2 단계, 이미지 1개 중 1개
    • Carefully pull the frame away from the glass.
    • If it doesn't remove easily, use the iFixit Opening Tool again to pry stuck sections.
  3. HP Photosmart c4780 Scanner Glass Replacement: 3 단계, 이미지 1개 중 1개
    • Use a T10 screwdriver to unscrew the two screws that fasten the frame to the printer hood.
  4. HP Photosmart c4780 Scanner Glass Replacement: 4 단계, 이미지 2개 중 1개 HP Photosmart c4780 Scanner Glass Replacement: 4 단계, 이미지 2개 중 2개
    • Put your finger behind the panel with the power button.
    • Then, pull the piece outwards.
  5. HP Photosmart c4780 Scanner Glass Replacement: 5 단계, 이미지 2개 중 1개 HP Photosmart c4780 Scanner Glass Replacement: 5 단계, 이미지 2개 중 2개
    • Unscrew the screw inside the power button panel space.
    • Then, unscrew the screw that is across the printer slider.
  6. HP Photosmart c4780 Scanner Glass Replacement: 6 단계, 이미지 1개 중 1개
    • Pull the white circuit board outwards which is located under the small screen.
    • Unplug the small ribbon cable from the circuit board.
    • Be careful when you unplug the ribbon cable not to use too much force. Using too much force may damage or rip the cable.
    • Unplug the small ribbon cable from the circuit board. Be careful when you unplug the ribbon cable not to use too much force. Using too much force may damage or rip the cable.
  7. HP Photosmart c4780 Scanner Glass Replacement: 8 단계, 이미지 2개 중 1개 HP Photosmart c4780 Scanner Glass Replacement: 8 단계, 이미지 2개 중 2개
    • Pull the memory card reader's circuit board out.
    • Detach the white wiring connector from the back of the circuit board.
    • You may need to use a finger nail or a plastic opening tool to detach the white wiring connector from the circuit board.
  8. HP Photosmart c4780 Scanner Glass Replacement: 9 단계, 이미지 2개 중 1개 HP Photosmart c4780 Scanner Glass Replacement: 9 단계, 이미지 2개 중 2개
    • Put your finger behind the small screen.
    • Then, pull it up.
    • Do not hesitate to use force to remove the TouchSmart panel.
    • Disconnect the ribbon cable from the small screen.
  9. HP Photosmart c4780 Scanner Glass Replacement: 10 단계, 이미지 1개 중 1개
    • Pull the printer hood upward.
  10. HP Photosmart c4780 Scanner Glass Replacement, Scanner Glass: 11 단계, 이미지 1개 중 1개
    • With the top half of the printer separated, lift the upper section with the scanner glass away from the lower section of the printer.
  11. HP Photosmart c4780 Scanner Glass Replacement: 12 단계, 이미지 2개 중 1개 HP Photosmart c4780 Scanner Glass Replacement: 12 단계, 이미지 2개 중 2개
    • With the glass facing upwards, remove the screw holding the glass in place.
  12. HP Photosmart c4780 Scanner Glass Replacement: 13 단계, 이미지 1개 중 1개
    • Lift the glass up and away from the printer.
    • Handle glass with care.
    • Replace the broken glass piece with the replacement glass
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
garrett hall
회원 가입일: 09/26/12
49 평판
안내서 2개를 작성함
Cal Poly, Team 2-11, Propen Fall 2012 Cal Poly, Team 2-11, Propen Fall 2012 회원
CPSU-PROPEN-F12S2G11
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 10
전체 시간: 3,378
