주요 콘텐츠로 건너뛰기
HP Prime Graphing Calculator G8X92A Battery Replacement
필요한 것
  1. HP Prime Graphing Calculator G8X92A Battery Replacement, Battery: 1 단계, 이미지 1/2 HP Prime Graphing Calculator G8X92A Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Power down the device.
    • Flip the device face side down so the back of the device is facing up.
  2. HP Prime Graphing Calculator G8X92A Battery Replacement: 2 단계, 이미지 1/3 HP Prime Graphing Calculator G8X92A Battery Replacement: 2 단계, 이미지 2/3 HP Prime Graphing Calculator G8X92A Battery Replacement: 2 단계, 이미지 3/3
    • Using a Phillips #00 screwdriver, remove the two 4.5 mm screws securing the battery cover located at the bottom center of the device.
    • Remove the cover.
  3. HP Prime Graphing Calculator G8X92A Battery Replacement: 3 단계, 이미지 1/3 HP Prime Graphing Calculator G8X92A Battery Replacement: 3 단계, 이미지 2/3 HP Prime Graphing Calculator G8X92A Battery Replacement: 3 단계, 이미지 3/3
    • Remove the battery.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Eric A Bidema
회원 가입일: 09/16/20
379 평판
안내서 3개 작성하였습니다
댓글 2개
The link to the battery in the "what you need" section is not correct. The battery is the same as the Samsung Galaxy S3. It has dimensions of approximately 50mmx63mmx5.5mm, with a 4-terminal connector on the top. it is 3.7VDC/7.4Wh. The one that comes with the calculator is "rated" at 2000mAh (whatever that means these days, as battery specs are often works of fiction).
m_a_s - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 23
30일 전: 132
전체 시간: 4,656
