주요 콘텐츠로 건너뛰기
HP ProBook 4320t Keyboard Replacement Guide
필요한 것
  1. HP ProBook 4320t Keyboard Replacement Guide, Battery Removal: 1 단계, 이미지 2개 중 1개 HP ProBook 4320t Keyboard Replacement Guide, Battery Removal: 1 단계, 이미지 2개 중 2개
    • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
  2. HP ProBook 4320t Keyboard Replacement Guide, Screws: 2 단계, 이미지 2개 중 1개 HP ProBook 4320t Keyboard Replacement Guide, Screws: 2 단계, 이미지 2개 중 2개
    • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
  3. HP ProBook 4320t Keyboard Replacement Guide, Flip: 3 단계, 이미지 1개 중 1개
    • Flip laptop over and open it.
  4. HP ProBook 4320t Keyboard Replacement Guide, Push N Lift: 4 단계, 이미지 1개 중 1개
    • Slightly push up while lifting up on the power button panel to release the panel.
  5. HP ProBook 4320t Keyboard Replacement Guide, Unscrewing: 5 단계, 이미지 1개 중 1개
    • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
  6. HP ProBook 4320t Keyboard Replacement Guide, Careful Now: 6 단계, 이미지 2개 중 1개 HP ProBook 4320t Keyboard Replacement Guide, Careful Now: 6 단계, 이미지 2개 중 2개
    • Carefully (holding both sides of the keyboard), push up and lift slightly.
    • Keyboard is still connected via a ribbon cable.
    • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
  7. HP ProBook 4320t Keyboard Replacement Guide, Disconnect Wire: 7 단계, 이미지 1개 중 1개
    • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
결론
작성자
4다른 기여자 명과 함께
Joshua
회원 가입일: 09/23/14
134 평판
안내서 6개를 작성함
USF Tampa, Team 9-5, Blackwell Fall 2014 USF Tampa, Team 9-5, Blackwell Fall 2014 회원
USFT-BLACKWELL-F14S9G5
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 7
전체 시간: 1,100
