주요 콘텐츠로 건너뛰기
HP ProBook 4320t Processor Heat Sink Replacement Guide
필요한 것
  1. HP ProBook 4320t Processor Heat Sink Replacement Guide, Battery Removal: 1 단계, 이미지 2개 중 1개 HP ProBook 4320t Processor Heat Sink Replacement Guide, Battery Removal: 1 단계, 이미지 2개 중 2개
    • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
  2. HP ProBook 4320t Processor Heat Sink Replacement Guide, Screws: 2 단계, 이미지 2개 중 1개 HP ProBook 4320t Processor Heat Sink Replacement Guide, Screws: 2 단계, 이미지 2개 중 2개
    • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
  3. HP ProBook 4320t Processor Heat Sink Replacement Guide, Flip: 3 단계, 이미지 1개 중 1개
    • Flip laptop over and open it.
  4. HP ProBook 4320t Processor Heat Sink Replacement Guide, Push N Lift: 4 단계, 이미지 1개 중 1개
    • Slightly push up while lifting up on the power button panel to release the panel.
  5. HP ProBook 4320t Processor Heat Sink Replacement Guide, Unscrewing: 5 단계, 이미지 1개 중 1개
    • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
  6. HP ProBook 4320t Processor Heat Sink Replacement Guide, Careful Now: 6 단계, 이미지 2개 중 1개 HP ProBook 4320t Processor Heat Sink Replacement Guide, Careful Now: 6 단계, 이미지 2개 중 2개
    • Carefully (holding both sides of the keyboard), push up and lift slightly.
    • Keyboard is still connected via a ribbon cable.
    • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
  7. HP ProBook 4320t Processor Heat Sink Replacement Guide, Disconnect Wire: 7 단계, 이미지 1개 중 1개
    • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
  8. HP ProBook 4320t Processor Heat Sink Replacement Guide, Unscrew: 8 단계, 이미지 1개 중 1개
    • Unscrew the three (2.5 mm Phillips) screws holding the bottom touchpad panel.
  9. HP ProBook 4320t Processor Heat Sink Replacement Guide, Slide the Panel Off: 9 단계, 이미지 1개 중 1개
    • Carefully slide the bottom panel to the right.
    • Keyboard is connected via a wire to the back of the panel.
  10. HP ProBook 4320t Processor Heat Sink Replacement Guide, Lift up Carefully: 10 단계, 이미지 1개 중 1개
    • Flip the bottom touchpad panel directly towards the screen, being sure to not lift it too high.
    • Keep an eye on the ZIF connector underneath, make sure it is not pulled accidentally.
  11. HP ProBook 4320t Processor Heat Sink Replacement Guide, Disconnect Wire: 11 단계, 이미지 1개 중 1개
    • Using the black spudger, slightly pry up on the ZIF connector and lift out the wire carefully.
  12. HP ProBook 4320t Processor Heat Sink Replacement Guide, Computer Fan: 12 단계, 이미지 1개 중 1개
    • Locate silver holding panel on the left side of the computer.
  13. HP ProBook 4320t Processor Heat Sink Replacement Guide: 13 단계, 이미지 1개 중 1개
    • Unscrew the five silver (2.5 mm Phillips) screws that are holding the panel in.
    • Unscrew the two black (3.0 mm Phillips) screws that are holding the panel in.
  14. HP ProBook 4320t Processor Heat Sink Replacement Guide: 14 단계, 이미지 1개 중 1개
    • Remove holding panel and put aside.
  15. HP ProBook 4320t Processor Heat Sink Replacement Guide: 15 단계, 이미지 1개 중 1개
    • Disconnect the red, black, and blue ribbon cable connector using the black spudger.
  16. HP ProBook 4320t Processor Heat Sink Replacement Guide: 16 단계, 이미지 1개 중 1개
    • Unscrew the one (2.0 mm Phillips) screw holding in the fan.
  17. HP ProBook 4320t Processor Heat Sink Replacement Guide: 17 단계, 이미지 1개 중 1개
    • Lift fan up carefully and replace.
  18. HP ProBook 4320t Processor Heat Sink Replacement Guide, Processor Heat Sink: 18 단계, 이미지 1개 중 1개
    • Unscrew the four (2.5 mm Phillips) screws holding the processor heat sink in (located near the center of the laptop)
  19. HP ProBook 4320t Processor Heat Sink Replacement Guide: 19 단계, 이미지 1개 중 1개
    • Lift slightly on the main component of the heat sink and slowly pull in towards the center (to your right) to free the heat sink.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Eric Markham
회원 가입일: 08/29/14
227 평판
안내서 4개를 작성함
USF Tampa, Team 9-5, Blackwell Fall 2014 USF Tampa, Team 9-5, Blackwell Fall 2014 회원
USFT-BLACKWELL-F14S9G5
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 13
전체 시간: 1,202
