주요 콘텐츠로 건너뛰기
HP ProBook 4320t Speakers Replacement Guide
필요한 것
  1. HP ProBook 4320t Speakers Replacement Guide, Battery Removal: 1 단계, 이미지 2개 중 1개 HP ProBook 4320t Speakers Replacement Guide, Battery Removal: 1 단계, 이미지 2개 중 2개
    • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
  2. HP ProBook 4320t Speakers Replacement Guide, Screws: 2 단계, 이미지 2개 중 1개 HP ProBook 4320t Speakers Replacement Guide, Screws: 2 단계, 이미지 2개 중 2개
    • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
  3. HP ProBook 4320t Speakers Replacement Guide, Flip: 3 단계, 이미지 1개 중 1개
    • Flip laptop over and open it.
  4. HP ProBook 4320t Speakers Replacement Guide, Push N Lift: 4 단계, 이미지 1개 중 1개
    • Slightly push up while lifting up on the power button panel to release the panel.
  5. HP ProBook 4320t Speakers Replacement Guide, Unscrewing: 5 단계, 이미지 1개 중 1개
    • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
  6. HP ProBook 4320t Speakers Replacement Guide, Careful Now: 6 단계, 이미지 2개 중 1개 HP ProBook 4320t Speakers Replacement Guide, Careful Now: 6 단계, 이미지 2개 중 2개
    • Carefully (holding both sides of the keyboard), push up and lift slightly.
    • Keyboard is still connected via a ribbon cable.
    • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
  7. HP ProBook 4320t Speakers Replacement Guide, Disconnect Wire: 7 단계, 이미지 1개 중 1개
    • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
  8. HP ProBook 4320t Speakers Replacement Guide, Speakers: 8 단계, 이미지 1개 중 1개
    • Use the black spudger tool to lift the white, black, and red ribbon cable connector up so that it is disconnected.
  9. HP ProBook 4320t Speakers Replacement Guide: 9 단계, 이미지 1개 중 1개
    • Unscrew the two (2.5 mm Phillips) screws (located on the upper most part of the computer) holding the speakers in.
  10. HP ProBook 4320t Speakers Replacement Guide: 10 단계, 이미지 1개 중 1개
    • Using the black spudger tool, gently pry off the right speaker.
    • Be careful to not break the cord.
  11. HP ProBook 4320t Speakers Replacement Guide: 11 단계, 이미지 1개 중 1개
    • Remove the cords from the retention clips.
  12. HP ProBook 4320t Speakers Replacement Guide: 12 단계, 이미지 1개 중 1개
    • Remove the left speaker as completed in step #10.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Eric Markham
회원 가입일: 08/29/14
227 평판
안내서 4개를 작성함
USF Tampa, Team 9-5, Blackwell Fall 2014 USF Tampa, Team 9-5, Blackwell Fall 2014 회원
USFT-BLACKWELL-F14S9G5
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 649
