주요 콘텐츠로 건너뛰기
HP ProBook 4320t Touchpad Replacement Guide
필요한 것
  1. HP ProBook 4320t Touchpad Replacement Guide, Battery Removal: 1 단계, 이미지 2개 중 1개 HP ProBook 4320t Touchpad Replacement Guide, Battery Removal: 1 단계, 이미지 2개 중 2개
    • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
  2. HP ProBook 4320t Touchpad Replacement Guide, Screws: 2 단계, 이미지 2개 중 1개 HP ProBook 4320t Touchpad Replacement Guide, Screws: 2 단계, 이미지 2개 중 2개
    • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
  3. HP ProBook 4320t Touchpad Replacement Guide, Flip: 3 단계, 이미지 1개 중 1개
    • Flip laptop over and open it.
  4. HP ProBook 4320t Touchpad Replacement Guide, Push N Lift: 4 단계, 이미지 1개 중 1개
    • Slightly push up while lifting up on the power button panel to release the panel.
  5. HP ProBook 4320t Touchpad Replacement Guide, Unscrewing: 5 단계, 이미지 1개 중 1개
    • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
  6. HP ProBook 4320t Touchpad Replacement Guide, Careful Now: 6 단계, 이미지 2개 중 1개 HP ProBook 4320t Touchpad Replacement Guide, Careful Now: 6 단계, 이미지 2개 중 2개
    • Carefully (holding both sides of the keyboard), push up and lift slightly.
    • Keyboard is still connected via a ribbon cable.
    • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
  7. HP ProBook 4320t Touchpad Replacement Guide, Disconnect Wire: 7 단계, 이미지 1개 중 1개
    • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
  8. HP ProBook 4320t Touchpad Replacement Guide, Unscrew: 8 단계, 이미지 1개 중 1개
    • Unscrew the three (2.5 mm Phillips) screws holding the bottom touchpad panel.
  9. HP ProBook 4320t Touchpad Replacement Guide, Slide the Panel Off: 9 단계, 이미지 1개 중 1개
    • Carefully slide the bottom panel to the right.
    • Keyboard is connected via a wire to the back of the panel.
  10. HP ProBook 4320t Touchpad Replacement Guide, Lift up Carefully: 10 단계, 이미지 1개 중 1개
    • Flip the bottom touchpad panel directly towards the screen, being sure to not lift it too high.
    • Keep an eye on the ZIF connector underneath, make sure it is not pulled accidentally.
  11. HP ProBook 4320t Touchpad Replacement Guide, Disconnect Wire: 11 단계, 이미지 1개 중 1개
    • Using the black spudger, slightly pry up on the ZIF connector and lift out the wire carefully.
  12. HP ProBook 4320t Touchpad Replacement Guide, Unscrewing: 12 단계, 이미지 1개 중 1개
    • Unscrew the two (2.5 mm Phillips) screws on the touch pad retention panel (Use Phillips #0 screw driver).
  13. HP ProBook 4320t Touchpad Replacement Guide, Remove Retention Panel: 13 단계, 이미지 1개 중 1개
    • Slightly push the touch pad retention panel forward to remove from clasp and lift up.
  14. HP ProBook 4320t Touchpad Replacement Guide, Touch Pad Screws: 14 단계, 이미지 1개 중 1개
    • Unscrew the following two (2.0 mm Phillips) screws attached to the touchpad (Use Phillips #0 screw driver).
  15. HP ProBook 4320t Touchpad Replacement Guide, Remove Touchpad: 15 단계, 이미지 1개 중 1개
    • Slightly lift up the bottom of the touchpad and pull towards you to free the touchpad from the casing
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Joshua
회원 가입일: 09/23/14
134 평판
안내서 6개를 작성함
USF Tampa, Team 9-5, Blackwell Fall 2014 USF Tampa, Team 9-5, Blackwell Fall 2014 회원
USFT-BLACKWELL-F14S9G5
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 1,466
