주요 콘텐츠로 건너뛰기
HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement
필요한 것
  1. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Battery: 1 단계, 이미지 1/2 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Battery: 1 단계, 이미지 2/2
    • Make sure the laptop is turned off before you start.
    • Push and hold the release tab on the right and left toward the center.
  2. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: 2 단계, 이미지 1/2 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: 2 단계, 이미지 2/2
    • Pull the battery out.
  3. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Backplate: 3 단계, 이미지 1/3 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Backplate: 3 단계, 이미지 2/3 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Backplate: 3 단계, 이미지 3/3
    • Push and hold the release tabs on the right and left toward the center again.
  4. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: 4 단계, 이미지 1/1
    • Slide the backplate off.
  5. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Hard Disc Drive (HDD): 5 단계, 이미지 1/2 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Hard Disc Drive (HDD): 5 단계, 이미지 2/2
    • Locate the hard drive, opposite the battery across from the wireless card.
  6. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: 6 단계, 이미지 1/3 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: 6 단계, 이미지 2/3 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: 6 단계, 이미지 3/3
    • Remove all four Phillips #00 screws that hold the hard drive in place.
  7. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: 7 단계, 이미지 1/3 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: 7 단계, 이미지 2/3 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: 7 단계, 이미지 3/3
    • Lift up on the outer part of the hard drive.
    • Pull the hard drive out.
  8. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: 8 단계, 이미지 1/2 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: 8 단계, 이미지 2/2
    • Remove the four Phillips #00 screws holding the HDD in the HDD cover.
    • The HDD should slide out after all screws are removed.
결론
Ethan A Courtney
회원 가입일: 10/24/18
851 평판
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 21
30일 전: 73
전체 시간: 4,222
