소개
A computer fan is a part that is constantly in use while the computer is on. This can cause it to eventually fail. This guide will show you how to replace your fan in order to extend the life of your laptop.
필요한 것
Push the release on the right side of the computer to the center.
Push and hold the release on the left side of the computer towards the center.
Unscrew the 2.5 mm screw with PH00 screwdriver.
Pull the cover off the computer using two hands.
Remove the 2.5 torx screw.
Pivot the spudger between the hard-drive and the optical drive. Push the optical drive away from the center of the computer.
다른 8명이 해당 안내서를 완성하였습니다.
댓글 2개
The 4 screws in the corners under the black rubber pads are missing in this guide!
Marc Brehm - 답글
