소개
If your HP ProBook 450 G4 is no longer able to play audio or video from a disk or if the video quality is poor, this indicates that there is a problem with your disk drive. This issue becomes more prevalent as your laptop ages and depending on how often you use your disk drive. We recommend replacing the disk drive to solve these issues. This guide is designed to help you safely and properly remove your laptop’s disk drive in an easy to follow way. Before beginning, make sure to power off your laptop and disconnect it from all power sources.
필요한 것
Flip the laptop over.
Orient the laptop so the two vents on the bottom face upward and are further away from you.
