주요 콘텐츠로 건너뛰기
HP ProBook 450 G4 Disk Drive Replacement
필요한 것
  1. HP ProBook 450 G4 Disk Drive Replacement, Disk Drive: 1 단계, 이미지 1/2 HP ProBook 450 G4 Disk Drive Replacement, Disk Drive: 1 단계, 이미지 2/2
    • Power your laptop off.
    • Flip the laptop over.
    • Orient the laptop so the two vents on the bottom face upward and are further away from you.
  2. HP ProBook 450 G4 Disk Drive Replacement: 2 단계, 이미지 1/3 HP ProBook 450 G4 Disk Drive Replacement: 2 단계, 이미지 2/3 HP ProBook 450 G4 Disk Drive Replacement: 2 단계, 이미지 3/3
    • Use the Phillips #0 screwdriver to remove the 6.8 mm screw that secures the vent panel to the laptop.
    • Use the spudger to separate the vent panel from the laptop.
    • Slide the vent panel off the backside of the laptop.
  3. HP ProBook 450 G4 Disk Drive Replacement: 3 단계, 이미지 1/2 HP ProBook 450 G4 Disk Drive Replacement: 3 단계, 이미지 2/2
    • Use the Phillips #0 screwdriver to remove the black 3.2mm screw that secures the disk drive to the left side of the laptop.
  4. HP ProBook 450 G4 Disk Drive Replacement: 4 단계, 이미지 1/2 HP ProBook 450 G4 Disk Drive Replacement: 4 단계, 이미지 2/2
    • Use the spudger to push the disk drive out of the laptop.
결론
Sebastian Dow
회원 가입일: 01/23/20
1,007 평판
안내서 6개 작성하였습니다
Cal Poly, Team S1-G3, White Winter 2020 Cal Poly, Team S1-G3, White Winter 2020 회원
CPSU-WHITE-W20S1G3
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 11
전체 시간: 522
