주요 콘텐츠로 건너뛰기
HP ProBook 450 G4 Display Assembly Replacement
필요한 것
  1. HP ProBook 450 G4 Display Assembly Replacement, Back Panel: 1 단계, 이미지 2개 중 1개 HP ProBook 450 G4 Display Assembly Replacement, Back Panel: 1 단계, 이미지 2개 중 2개
    • Power off your laptop and flip it over so that the bottom faces upward.
    • Use the Phillips #0 screwdriver to remove the screw securing the service door.
    • Use a Jimmy to remove the service door.
  2. HP ProBook 450 G4 Display Assembly Replacement, Display Assembly: 2 단계, 이미지 2개 중 1개 HP ProBook 450 G4 Display Assembly Replacement, Display Assembly: 2 단계, 이미지 2개 중 2개
    • Use a Phillips #0 screwdriver to remove the two 6.6mm screws.
    • Remove the black 3.2mm screw that secures the hard drive to the left side of the laptop with a Phillips #0 screwdriver.
    • Use the spudger to lift the left side of the hard drive, and remove.
  3. HP ProBook 450 G4 Display Assembly Replacement: 3 단계, 이미지 2개 중 1개 HP ProBook 450 G4 Display Assembly Replacement: 3 단계, 이미지 2개 중 2개
    • Remove all 6.6 mm T8 Torx screws, including where the hard drive used to be.
  4. HP ProBook 450 G4 Display Assembly Replacement: 4 단계, 이미지 2개 중 1개 HP ProBook 450 G4 Display Assembly Replacement: 4 단계, 이미지 2개 중 2개
    • Unclip the wires from the Wi-Fi card.
    • Remove the Wi-Fi card.
  5. HP ProBook 450 G4 Display Assembly Replacement: 5 단계, 이미지 3개 중 1개 HP ProBook 450 G4 Display Assembly Replacement: 5 단계, 이미지 3개 중 2개 HP ProBook 450 G4 Display Assembly Replacement: 5 단계, 이미지 3개 중 3개
    • Flip the laptop over, and use a Jimmy to loosen the keypad from the laptop.
    • Use the spudger to unclip the tab.
    • Remove the top case once all tabs are loose.
  6. HP ProBook 450 G4 Display Assembly Replacement: 6 단계, 이미지 1개 중 1개
    • Use the spudger to disconnect the black wire.
  7. HP ProBook 450 G4 Display Assembly Replacement: 7 단계, 이미지 2개 중 1개 HP ProBook 450 G4 Display Assembly Replacement: 7 단계, 이미지 2개 중 2개
    • Use the Phillips #0 screwdriver to remove the two 3.2mm screws from the hinges.
    • Repeat on both sides.
  8. HP ProBook 450 G4 Display Assembly Replacement: 8 단계, 이미지 1개 중 1개
    • Remove and replace the display assembly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Nat Robinson
회원 가입일: 02/08/24
169 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 11
지난 30일: 33
전체 시간: 464
