소개
If your HP ProBook 450 G4 keyboard is being unresponsive, there might be debris underneath the keys or there could be a faulty connection between the keyboard and the computer frame. The easiest way to fix these problems would be to clean the underside of your keyboard with an air compressor or to replace your keyboard. Before using this guide, make sure that the Filter Keys accessibility function is turned off. Sometimes this function can accidentally get turned on which can make it seem like your keystrokes are not being registered. To turn this function off, hold the right shift button for eight seconds, or disable it from the access center in the Windows control panel. If the Filter Keys accessibility function was not turned on, follow the instructions in this guide to safely and properly remove your laptop’s keyboard. Before beginning, make sure to power off your laptop and disconnect it from all power sources.
필요한 것
Flip the laptop over.
Orient the laptop so the two vents on the bottom face upward and are further away from you.
Remove the 6.6mm T8 Torx screw located below where the hard drive used to be.
Remove the 6.6mm T8 Torx screw located below and to the left of the circular, silver and black fan.
다른 한 분이 해당 안내서를 완성하였습니다.
