주요 콘텐츠로 건너뛰기
HP ProBook 4520s Hard Drive Replacement
필요한 것
  1. HP ProBook 4520s Hard Drive Replacement, Battery: 1 단계, 이미지 1/2 HP ProBook 4520s Hard Drive Replacement, Battery: 1 단계, 이미지 2/2
    • Flip the 4520s upside-down with the front toward you.
    • Push the two latches below the battery inwards at the same time.
  2. HP ProBook 4520s Hard Drive Replacement: 2 단계, 이미지 1/1
    • Remove the battery by holding the latches and sliding the battery away from you.
  3. HP ProBook 4520s Hard Drive Replacement, Switch Cover: 3 단계, 이미지 1/2 HP ProBook 4520s Hard Drive Replacement, Switch Cover: 3 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to remove three 2mm screws where the battery was located.
  4. HP ProBook 4520s Hard Drive Replacement: 4 단계, 이미지 1/2 HP ProBook 4520s Hard Drive Replacement: 4 단계, 이미지 2/2
    • Flip the 4520s over and rotate it so the back is facing you.
    • Use a metal spudger to peel off two rubber caps located on either side of the battery port.
  5. HP ProBook 4520s Hard Drive Replacement: 5 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver to remove the 3mm screws behind the caps.
  6. HP ProBook 4520s Hard Drive Replacement: 6 단계, 이미지 1/3 HP ProBook 4520s Hard Drive Replacement: 6 단계, 이미지 2/3 HP ProBook 4520s Hard Drive Replacement: 6 단계, 이미지 3/3
    • Rotate the 4520s and then open it with the screen facing you.
    • The switch cover is located above the keyboard. Push the switch cover away from you until it comes loose from the 4520s.
    • Lift the switch cover away from the 4520s and set it aside.
  7. HP ProBook 4520s Hard Drive Replacement, Keyboard: 7 단계, 이미지 1/2 HP ProBook 4520s Hard Drive Replacement, Keyboard: 7 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to remove the two 7mm screws located on either side of the keyboard panel.
  8. HP ProBook 4520s Hard Drive Replacement: 8 단계, 이미지 1/1
    • Slide the keyboard panel away from you to free it from the 4520s.
    • Do not yank the keyboard panel away from the 4520s. This may damage the cable.
  9. HP ProBook 4520s Hard Drive Replacement: 9 단계, 이미지 1/2 HP ProBook 4520s Hard Drive Replacement: 9 단계, 이미지 2/2
    • Gently raise up the keyboard and flip it over to reveal a ribbon cable.
    • Release the ribbon cable by carefully lifting the black tab upwards, one side at a time.
    • Remove the cable and lift the keyboard panel up. Set it aside.
    • When reassembling, feed the ribbon cable into the port. Press down on the tab to pinch the cable in place.
  10. HP ProBook 4520s Hard Drive Replacement, Palm Rest: 10 단계, 이미지 1/2 HP ProBook 4520s Hard Drive Replacement, Palm Rest: 10 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to remove the three 3mm screws along the top of the palm rest.
  11. HP ProBook 4520s Hard Drive Replacement: 11 단계, 이미지 1/2 HP ProBook 4520s Hard Drive Replacement: 11 단계, 이미지 2/2
    • Slide the palm rest to the right to release it and then rotate it back gently.
    • Do not yank the palm rest away from the 4520s. This may damage the cable.
  12. HP ProBook 4520s Hard Drive Replacement: 12 단계, 이미지 1/2 HP ProBook 4520s Hard Drive Replacement: 12 단계, 이미지 2/2
    • Release the ribbon cable by opening the black hinge on the port using a spudger.
    • Remove the cable and set the palm rest aside.
  13. HP ProBook 4520s Hard Drive Replacement, Hard Drive: 13 단계, 이미지 1/3 HP ProBook 4520s Hard Drive Replacement, Hard Drive: 13 단계, 이미지 2/3 HP ProBook 4520s Hard Drive Replacement, Hard Drive: 13 단계, 이미지 3/3
    • The hard drive is contained in the housing on the lower right.
    • Remove two 5mm screws on the left using a Phillips #1 screwdriver.
    • Fully loosen the captive screw on the right using a Phillips #1 screwdriver.
  14. HP ProBook 4520s Hard Drive Replacement: 14 단계, 이미지 1/2 HP ProBook 4520s Hard Drive Replacement: 14 단계, 이미지 2/2
    • Disconnect the hard drive by pulling the tab to the right.
    • Lift the housing out from the 4520s.
  15. HP ProBook 4520s Hard Drive Replacement: 15 단계, 이미지 1/2 HP ProBook 4520s Hard Drive Replacement: 15 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to remove the four 3mm screws on the sides of the housing.
  16. HP ProBook 4520s Hard Drive Replacement: 16 단계, 이미지 1/1
    • Lift the housing away from the hard drive.
    • The hard drive is 2.5".
결론
다른 50명이 해당 안내서를 완성하였습니다.
May Lin
회원 가입일: 09/21/16
811 평판
안내서 1개 작성함
UC Davis, Team 1-3, Oliver Fall 2016 UC Davis, Team 1-3, Oliver Fall 2016 회원
UCD-OLIVER-F16S1G3
5 회원들
안내서 8개 작성하였습니다
4 댓글
is it 2.5" HDD ?
Bf Soldier - 답글
Yes. I should have included that.
Robert Spencer Harrison -
Thank you so much lol
You taught me that i didn’t have to throw and break this darn machine to get the hard drive out :P
M
Maria Sergent - 답글
Thank you!
This guide works well for the 4320s as well, though there are a few small differences.
The battery compartment has 4 screws and there are none on the back.
The keyboard is held by 4 screws.
The touchpad has the same type of connector as the keyboard.
The hard drive cage is held by a #1 Philips and two #0 Philips instead of #1.
Carl - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 34
30일 전: 223
전체 시간: 36,452
