소개
If your HP ProBook 4520s shuts down without warning, you may have a hard drive error and need to replace the hard drive.
Flip the 4520s upside-down with the front toward you.
Push the two latches below the battery inwards at the same time.
Use a Phillips #1 screwdriver to remove three 2mm screws where the battery was located.
Use a Phillips #1 screwdriver to remove the two 7mm screws located on either side of the keyboard panel.
Slide the keyboard panel away from you to free it from the 4520s.
Does keyboard slide away or to right/left? thought it was to the right.
Heidi Bell - 답글
Keyboard goes directly away
Use a Phillips #1 screwdriver to remove the three 3mm screws along the top of the palm rest.
The hard drive is contained in the housing on the lower right.
Remove two 5mm screws on the left using a Phillips #1 screwdriver.
Fully loosen the captive screw on the right using a Phillips #1 screwdriver.
다른 47명이 해당 안내서를 완성하였습니다.
댓글 3개
is it 2.5" HDD ?
Bf Soldier - 답글
Yes. I should have included that.
Thank you so much lol
You taught me that i didn’t have to throw and break this darn machine to get the hard drive out :P
M
