이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Flip the 4520s upside-down with the front toward you.
Push the two latches below the battery inwards at the same time.
Remove the battery by holding the latches and sliding the battery away from you.
Use a Phillips #1 screwdriver to remove three 2mm screws where the battery was located.
Flip the 4520s over and rotate it so the back is facing you.
Use a metal spudger to peel off two rubber caps located on either side of the battery port.
Use a Phillips #1 screwdriver to remove the 3mm screws behind the caps.
Rotate the 4520s and then open it with the screen facing you.
The switch cover is located above the keyboard. Push the switch cover away from you until it comes loose from the 4520s.
Lift the switch cover away from the 4520s and set it aside.
Use a Phillips #1 screwdriver to remove the two 7mm screws located on either side of the keyboard panel.
Gently raise up the keyboard and flip it over to reveal a ribbon cable.
Release the ribbon cable by carefully lifting the black tab upwards, one side at a time.
Remove the cable and lift the keyboard panel up. Set it aside.
Use a Phillips #1 screwdriver to remove the three 3mm screws along the top of the palm rest.
Slide the palm rest to the right to release it and then rotate it back gently.
Release the ribbon cable by opening the black hinge on the port using a spudger.
Remove the cable and set the palm rest aside.
The hard drive is contained in the housing on the lower right.
Remove two 5mm screws on the left using a Phillips #1 screwdriver.
Fully loosen the captive screw on the right using a Phillips #1 screwdriver.
Disconnect the hard drive by pulling the tab to the right.
Lift the housing out from the 4520s.
Use a Phillips #1 screwdriver to remove the four 3mm screws on the sides of the housing.
다른 53명이 해당 안내서를 완성하였습니다.
댓글 5개
is it 2.5" HDD ?
Bf Soldier - 답글
Yes. I should have included that.
Thank you so much lol
You taught me that i didn’t have to throw and break this darn machine to get the hard drive out :P
M
Thank you!
This guide works well for the 4320s as well, though there are a few small differences.
The battery compartment has 4 screws and there are none on the back.
The keyboard is held by 4 screws.
The touchpad has the same type of connector as the keyboard.
The hard drive cage is held by a #1 Philips and two #0 Philips instead of #1.
