소개
If the keys on your keyboard are unresponsive or damaged, remove the keyboard for cleaning or replacement.
필요한 것
Flip the 4520s upside-down with the front toward you.
Push the two latches below the battery inwards at the same time.
Use a Phillips #1 screwdriver to remove three 2mm screws where the battery was located.
Use a Phillips #1 screwdriver to remove the two 7mm screws located on either side of the keyboard panel.
To reassemble your device, follow these steps in reverse order.
다른 7명이 해당 안내서를 완성하였습니다.
