주요 콘텐츠로 건너뛰기
부품
지정된 부품이 없습니다.
  1. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Flip the 4520s upside-down with the front toward you. Push the two latches below the battery inwards at the same time.
    • Flip the 4520s upside-down with the front toward you.
    • Push the two latches below the battery inwards at the same time.
  2. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Remove the battery by holding the latches and sliding the battery away from you.
    • Remove the battery by holding the latches and sliding the battery away from you.
  3. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Use a Phillips #1 screwdriver to remove three 2mm screws where the battery was located. Use a Phillips #1 screwdriver to remove three 2mm screws where the battery was located.
    • Use a Phillips #1 screwdriver to remove three 2mm screws where the battery was located.
  4. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Flip the 4520s over and rotate it so the back is facing you. Use a metal spudger to peel off two rubber caps located on either side of the battery port.
    • Flip the 4520s over and rotate it so the back is facing you.
    • Use a metal spudger to peel off two rubber caps located on either side of the battery port.
  5. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Use a Phillips #1 screwdriver to remove the 3mm screws behind the caps.
    • Use a Phillips #1 screwdriver to remove the 3mm screws behind the caps.
  6. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Rotate the 4520s and then open it with the screen facing you. The switch cover is located above the keyboard.  Push the switch cover away from you until it comes loose from the 4520s. Lift the switch cover away from the 4520s and set it aside.
    • Rotate the 4520s and then open it with the screen facing you.
    • The switch cover is located above the keyboard. Push the switch cover away from you until it comes loose from the 4520s.
    • Lift the switch cover away from the 4520s and set it aside.
  7. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Use a Phillips #1 screwdriver to remove the two 7mm screws located on either side of the keyboard panel. Use a Phillips #1 screwdriver to remove the two 7mm screws located on either side of the keyboard panel.
    • Use a Phillips #1 screwdriver to remove the two 7mm screws located on either side of the keyboard panel.
  8. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Slide the keyboard panel away from you to free it from the 4520s.
    • Slide the keyboard panel away from you to free it from the 4520s.
    • Do not yank the keyboard panel away from the 4520s. This may damage the cable.
  9. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Gently raise up the keyboard and flip it over to reveal a ribbon cable. Release the ribbon cable by carefully lifting the black tab upwards, one side at a time.
    • Gently raise up the keyboard and flip it over to reveal a ribbon cable.
    • Release the ribbon cable by carefully lifting the black tab upwards, one side at a time.
    • Remove the cable and lift the keyboard panel up. Set it aside.
    • When reassembling, feed the ribbon cable into the port. Press down on the tab to pinch the cable in place.
  10. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    The housing for the optical drive is on the right of the device. Remove the 5mm screw on the left side of the metal plate with a Phillips (PH1) head screwdriver.
    • The housing for the optical drive is on the right of the device.
    • Remove the 5mm screw on the left side of the metal plate with a Phillips (PH1) head screwdriver.
  11. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Use a metal spudger to push the optical drive to the right and partially out of the casing.
    • Use a metal spudger to push the optical drive to the right and partially out of the casing.
  12. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Slide the optical drive outward from the 4520s.
    • Slide the optical drive outward from the 4520s.
  13. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Use a Phillips (PH1) head screwdriver to remove two 2mm screws securing the metal tab to the optical drive. Use a Phillips (PH1) head screwdriver to remove two 2mm screws securing the metal tab to the optical drive.
    • Use a Phillips (PH1) head screwdriver to remove two 2mm screws securing the metal tab to the optical drive.
결승점
Nicholas Caruso
회원 가입일: 2016년 09월 21일
281 평판
안내서 1개 작성함
UC Davis, Team 1-3, Oliver Fall 2016 UC Davis, Team 1-3, Oliver Fall 2016 회원
UCD-OLIVER-F16S1G3
5 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 17
전체 시간: 2,066
