소개
If your laptop screen is cracked or appears dark while the computer is running, replace the screen.
Flip the 4520s upside-down with the front toward you.
Push the two latches below the battery inwards at the same time.
Use a Phillips #1 screwdriver to remove three 2mm screws where the battery was located.
거의 끝나갑니다!
결론
다른 6명이 해당 안내서를 완성하였습니다.
