주요 콘텐츠로 건너뛰기
소개
"Prerequisite Only"
Replace the HP ProBook 4520s switch cover as a prerequisite for other guides.
부품
지정된 부품이 없습니다.
  1. HP ProBook 4520s Switch Cover Replacement, Battery: 1 단계, 이미지 1/2 HP ProBook 4520s Switch Cover Replacement, Battery: 1 단계, 이미지 2/2
    • Flip the 4520s upside-down with the front toward you.
    • Push the two latches below the battery inwards at the same time.
  2. HP ProBook 4520s Switch Cover Replacement: 2 단계, 이미지 1/1
    • Remove the battery by holding the latches and sliding the battery away from you.
  3. HP ProBook 4520s Switch Cover Replacement, Switch Cover: 3 단계, 이미지 1/2 HP ProBook 4520s Switch Cover Replacement, Switch Cover: 3 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to remove three 2mm screws where the battery was located.
  4. HP ProBook 4520s Switch Cover Replacement: 4 단계, 이미지 1/2 HP ProBook 4520s Switch Cover Replacement: 4 단계, 이미지 2/2
    • Flip the 4520s over and rotate it so the back is facing you.
    • Use a metal spudger to peel off two rubber caps located on either side of the battery port.
  5. HP ProBook 4520s Switch Cover Replacement: 5 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver to remove the 3mm screws behind the caps.
  6. HP ProBook 4520s Switch Cover Replacement: 6 단계, 이미지 1/3 HP ProBook 4520s Switch Cover Replacement: 6 단계, 이미지 2/3 HP ProBook 4520s Switch Cover Replacement: 6 단계, 이미지 3/3
    • Rotate the 4520s and then open it with the screen facing you.
    • The switch cover is located above the keyboard. Push the switch cover away from you until it comes loose from the 4520s.
    • Lift the switch cover away from the 4520s and set it aside.
결론
Robert Spencer Harrison
회원 가입일: 2016년 09월 21일
1,286 평판
안내서 4개 작성하였습니다
UC Davis, Team 1-3, Oliver Fall 2016 UC Davis, Team 1-3, Oliver Fall 2016 회원
UCD-OLIVER-F16S1G3
5 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 167
