주요 콘텐츠로 건너뛰기
HP ProBook 4540s Back Door Replacement
필요한 것
  1. HP ProBook 4540s Back Door Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure the computer is shut off and the power cord is unplugged from the AC outlet.
    • Slide the two release latches on either side of the battery.
    • Gently tilt the battery upward and remove it from its socket.
  2. HP ProBook 4540s Back Door Replacement, Bottom Door: 2 단계, 이미지 1/1
    • Turn the computer so the bottom is facing towards you.
    • Remove the one 3.0 mm Phillips PM2.0x3.0 security screw.
    • The security screw is an optional feature and isn't required to hold the backing if there is not one screwed in place.
    • Slide the release latches then pull the door towards you. Lift the door away to completely remove it.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Amber Schindler
회원 가입일: 10/26/16
1,027 평판
안내서 6개 작성하였습니다
UW Tacoma, Team 1-5, Rose Fall 2016 UW Tacoma, Team 1-5, Rose Fall 2016 회원
UWT-ROSE-F16S1G5
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 31
전체 시간: 2,052
