주요 콘텐츠로 건너뛰기
HP ProBook 4540s Keyboard Replacement
필요한 것
  1. HP ProBook 4540s Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure the computer is shut off and the power cord is unplugged from the AC outlet.
    • Slide the two release latches on either side of the battery.
    • Gently tilt the battery upward and remove it from its socket.
  2. HP ProBook 4540s Keyboard Replacement, Bottom Door: 2 단계, 이미지 1/1
    • Turn the computer so the bottom is facing towards you.
    • Remove the one 3.0 mm Phillips PM2.0x3.0 security screw.
    • The security screw is an optional feature and isn't required to hold the backing if there is not one screwed in place.
    • Slide the release latches then pull the door towards you. Lift the door away to completely remove it.
  3. HP ProBook 4540s Keyboard Replacement, Keyboard: 3 단계, 이미지 1/1
    • Remove four 6.0 mm Phillips PM2.5x6.0 screws.
  4. HP ProBook 4540s Keyboard Replacement: 4 단계, 이미지 1/1
    • Turn the computer over and position it right-side up in order and open the computer as far as possible.
  5. HP ProBook 4540s Keyboard Replacement: 5 단계, 이미지 1/1
    • Move the keyboard in a downward fashion towards the palm rest.
  6. HP ProBook 4540s Keyboard Replacement: 6 단계, 이미지 1/1
    • Lift the top of the keyboard at an angle and then gently pull it up and away from the palm rest.
    • Only pull the keyboard up enough to release it. The cable beneath the keyboard will still be attached to the system board.
  7. HP ProBook 4540s Keyboard Replacement: 7 단계, 이미지 1/1
    • Disconnect the keyboard cable by lifting the latch at the center of the system board.
    • Completely remove the keyboard.
결론
다른 15명이 해당 안내서를 완성하였습니다.
Amber Schindler
회원 가입일: 10/26/16
1,027 평판
안내서 6개 작성하였습니다
UW Tacoma, Team 1-5, Rose Fall 2016 UW Tacoma, Team 1-5, Rose Fall 2016 회원
UWT-ROSE-F16S1G5
4 회원들
안내서 6개 작성하였습니다
댓글 2개
Precise and clear guide. Great Work!!!
Mario Mutale - 답글
Easy to follow and a great help to get the job done. Thanks
d1211109 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 29
전체 시간: 7,101
