소개
This guide will help you replace the optical drive, otherwise known as the CD drive. Be sure that no disks are within the drive before replacing the drive.
필요한 것
Slide the two release latches on either side of the battery.
Gently tilt the battery upward and remove it from its socket.
Turn the computer so the bottom is facing towards you.
Remove the one 3.0 mm Phillips PM2.0x3.0 security screw.
Slide the release latches then pull the door towards you. Lift the door away to completely remove it.
Remove one 6.0 mm Phillips PM2.5x6.0 screw that is securing the optical drive.
다른 3명이 해당 안내서를 완성하였습니다.
