주요 콘텐츠로 건너뛰기
HP ProBook 455 G1 Battery Replacement
  1. HP ProBook 455 G1 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the computer upside down on a flat side, so that you are seeing the underside of the laptop.
    • Before removing the battery, make sure that the computer is turned off and that the power cord is not plugged into the computer.
  2. HP ProBook 455 G1 Battery Replacement: 2 단계, 이미지 1/1
    • Slide the two battery release latches towards the center of the laptop to release the battery.
  3. HP ProBook 455 G1 Battery Replacement: 3 단계, 이미지 1/2 HP ProBook 455 G1 Battery Replacement: 3 단계, 이미지 2/2
    • Tilt the battery upward.
    • Remove it from the laptop.
결론
Jennifer Sexton
회원 가입일: 03/18/18
649 평판
안내서 4개 작성하였습니다
Baylor, Team S5-G1, Williams Spring 2018 Baylor, Team S5-G1, Williams Spring 2018 회원
BU-WILLIAMS-S18S5G1
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 9
전체 시간: 980
