주요 콘텐츠로 건너뛰기
HP ProBook 455 G1 DVD/CD Drive Replacement
필요한 것
  1. HP ProBook 455 G1 DVD/CD Drive  Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the computer upside down on a flat side, so that you are seeing the underside of the laptop.
    • Before removing the battery, make sure that the computer is turned off and that the power cord is not plugged into the computer.
  2. HP ProBook 455 G1 DVD/CD Drive  Replacement: 2 단계, 이미지 1/1
    • Slide the two battery release latches towards the center of the laptop to release the battery.
  3. HP ProBook 455 G1 DVD/CD Drive  Replacement: 3 단계, 이미지 1/2 HP ProBook 455 G1 DVD/CD Drive  Replacement: 3 단계, 이미지 2/2
    • Tilt the battery upward.
    • Remove it from the laptop.
  4. HP ProBook 455 G1 DVD/CD Drive  Replacement, Service Panel: 4 단계, 이미지 1/1
    • Slide the two release latches that were mentioned in the battery removal process to release the service panel.
  5. HP ProBook 455 G1 DVD/CD Drive  Replacement: 5 단계, 이미지 1/2 HP ProBook 455 G1 DVD/CD Drive  Replacement: 5 단계, 이미지 2/2
    • Slide the service panel toward you using your thumbs.
    • Lift it to remove the panel and reveal inner components of the computer.
  6. HP ProBook 455 G1 DVD/CD Drive  Replacement, DVD/CD Drive: 6 단계, 이미지 1/2 HP ProBook 455 G1 DVD/CD Drive  Replacement, DVD/CD Drive: 6 단계, 이미지 2/2
    • Using a Phillips P0 Screwdriver, remove the 6 millimeter screw that secures the DVD/CD drive to the computer.
    • It will be located in the upper left section of the computer, housed in a small square hole in the computer frame.
    • The Phillips head screwdriver is the screwdriver with a "+" shaped tip. P0 refers to the name/size of this particular Phillips head screwdriver.
  7. HP ProBook 455 G1 DVD/CD Drive  Replacement: 7 단계, 이미지 1/1
    • Using the screwdriver, gently push the silver tab that the screw secured to the left to release the DVD/CD drive from the computer.
  8. HP ProBook 455 G1 DVD/CD Drive  Replacement: 8 단계, 이미지 1/1
    • The DVD/CD drive will be extended from the side of the laptop. Slowly remove it from the computer.
결론
Jennifer Sexton
회원 가입일: 03/18/18
649 평판
안내서 4개 작성하였습니다
Baylor, Team S5-G1, Williams Spring 2018 Baylor, Team S5-G1, Williams Spring 2018 회원
BU-WILLIAMS-S18S5G1
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 10
전체 시간: 970
