주요 콘텐츠로 건너뛰기
HP ProBook 455 G1 Hard Drive Replacement
필요한 것
  1. HP ProBook 455 G1 Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the computer upside down on a flat side, so that you are seeing the underside of the laptop.
    • Before removing the battery, make sure that the computer is turned off and that the power cord is not plugged into the computer.
  2. HP ProBook 455 G1 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Slide the two battery release latches towards the center of the laptop to release the battery.
  3. HP ProBook 455 G1 Hard Drive Replacement: 3 단계, 이미지 1/2 HP ProBook 455 G1 Hard Drive Replacement: 3 단계, 이미지 2/2
    • Tilt the battery upward.
    • Remove it from the laptop.
  4. HP ProBook 455 G1 Hard Drive Replacement, Service Panel: 4 단계, 이미지 1/1
    • Slide the two release latches that were mentioned in the battery removal process to release the service panel.
  5. HP ProBook 455 G1 Hard Drive Replacement: 5 단계, 이미지 1/2 HP ProBook 455 G1 Hard Drive Replacement: 5 단계, 이미지 2/2
    • Slide the service panel toward you using your thumbs.
    • Lift it to remove the panel and reveal inner components of the computer.
  6. HP ProBook 455 G1 Hard Drive Replacement, Hard Drive: 6 단계, 이미지 1/2 HP ProBook 455 G1 Hard Drive Replacement, Hard Drive: 6 단계, 이미지 2/2
    • Using a Phillips #0 Screwdriver, remove the four Phillips 3 mm screws that secure the hard drive into the computer.
  7. HP ProBook 455 G1 Hard Drive Replacement: 7 단계, 이미지 1/1
    • Pull the hard drive cover tab to the left in order to disconnect the hard drive from the computer.
  8. HP ProBook 455 G1 Hard Drive Replacement: 8 단계, 이미지 1/1
    • Finally, using the same tab, lift the hard drive out of the hard drive port.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Bailey Brammer
회원 가입일: 03/18/18
343 평판
안내서 1개 작성함
Baylor, Team S5-G1, Williams Spring 2018 Baylor, Team S5-G1, Williams Spring 2018 회원
BU-WILLIAMS-S18S5G1
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 10
30일 전: 33
전체 시간: 7,307
