주요 콘텐츠로 건너뛰기
HP ProBook 650 G2 Battery Replacement
필요한 것
  1. HP ProBook 650 G2 Battery Replacement, Remove the case screws: 1 단계, 이미지 1/1
    • There are 8 case screws that all use a PH1 bit
  2. HP ProBook 650 G2 Battery Replacement, Pry open the case: 2 단계, 이미지 1/3 HP ProBook 650 G2 Battery Replacement, Pry open the case: 2 단계, 이미지 2/3 HP ProBook 650 G2 Battery Replacement, Pry open the case: 2 단계, 이미지 3/3
    • Start at the back near the hinge with a pry tool
    • Work your way around to the front using enough pressure to release the plastic clips
    • Once you get near the opposite corner it should release to a point where you can use your hand to pull it open
  3. HP ProBook 650 G2 Battery Replacement, Remove the battery: 3 단계, 이미지 1/2 HP ProBook 650 G2 Battery Replacement, Remove the battery: 3 단계, 이미지 2/2
    • There are 7 captive screws (on the original HP battery) around the edge of the battery that use a PH1 bit
    • Once the screws are removed you can use the tab nearest the front center of the laptop to lift the battery up and out
  4. HP ProBook 650 G2 Battery Replacement, (Optional) Remove captive screws: 4 단계, 이미지 1/1
    • If your new battery did not come with the captive screws you can unscrew them from the old battery by applying pressure under the screw while unscrewing them so you can transfer them to the new battery
결론
The Bearded IT Guy
회원 가입일: 08/27/23
109 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 26
전체 시간: 218
