주요 콘텐츠로 건너뛰기
HP ProBook x360 11 G5 EE Charging Port Replacement
필요한 것
  1. HP ProBook x360 11 G5 EE Charging Port Replacement, Keyboard Assembly: 1 단계, 이미지 1/3 HP ProBook x360 11 G5 EE Charging Port Replacement, Keyboard Assembly: 1 단계, 이미지 2/3 HP ProBook x360 11 G5 EE Charging Port Replacement, Keyboard Assembly: 1 단계, 이미지 3/3
    • Remove the 4.1 mm screws with a T5 Torx screwdriver.
    • Remove the 4.1 mm screws using a JIS #0 screwdriver.
  2. HP ProBook x360 11 G5 EE Charging Port Replacement: 2 단계, 이미지 1/1
    • Use an opening pick to pry the corners of the keyboard deck.
  3. HP ProBook x360 11 G5 EE Charging Port Replacement: 3 단계, 이미지 1/3 HP ProBook x360 11 G5 EE Charging Port Replacement: 3 단계, 이미지 2/3 HP ProBook x360 11 G5 EE Charging Port Replacement: 3 단계, 이미지 3/3
    • Use an opening pick or opening tool to pry around the sides of the keyboard assembly.
  4. HP ProBook x360 11 G5 EE Charging Port Replacement: 4 단계, 이미지 1/3 HP ProBook x360 11 G5 EE Charging Port Replacement: 4 단계, 이미지 2/3 HP ProBook x360 11 G5 EE Charging Port Replacement: 4 단계, 이미지 3/3
    • Lift the keyboard assembly to expose two ribbon cables.
    • Lift the two plastic tabs that hold the cables in place on the motherboard
    • Slide the ribbon cables out of each connector.
  5. HP ProBook x360 11 G5 EE Charging Port Replacement: 5 단계, 이미지 1/2 HP ProBook x360 11 G5 EE Charging Port Replacement: 5 단계, 이미지 2/2
    • Remove the keyboard assembly from the rest of the computer.
  6. HP ProBook x360 11 G5 EE Charging Port Replacement, Battery: 6 단계, 이미지 1/2 HP ProBook x360 11 G5 EE Charging Port Replacement, Battery: 6 단계, 이미지 2/2
    • Remove the four 3 mm screws from the battery with the JIS #0 screwdriver.
  7. HP ProBook x360 11 G5 EE Charging Port Replacement: 7 단계, 이미지 1/3 HP ProBook x360 11 G5 EE Charging Port Replacement: 7 단계, 이미지 2/3 HP ProBook x360 11 G5 EE Charging Port Replacement: 7 단계, 이미지 3/3
    • Pry the battery up from the laptop using an opening pick.
    • Lift the battery out of its place.
  8. HP ProBook x360 11 G5 EE Charging Port Replacement, Charging Port: 8 단계, 이미지 1/2 HP ProBook x360 11 G5 EE Charging Port Replacement, Charging Port: 8 단계, 이미지 2/2
    • Remove the single 3 mm screw from the charging port using a T5 Torx screwdriver.
  9. HP ProBook x360 11 G5 EE Charging Port Replacement: 9 단계, 이미지 1/3 HP ProBook x360 11 G5 EE Charging Port Replacement: 9 단계, 이미지 2/3 HP ProBook x360 11 G5 EE Charging Port Replacement: 9 단계, 이미지 3/3
    • Disconnect the charging port wire from the motherboard.
    • Remove the charging port from your device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Michelle Pina
회원 가입일: 10/26/21
506 평판
안내서 4개 작성하였습니다
Gateway, Team 1-4, Pee Fall 2021 Gateway, Team 1-4, Pee Fall 2021 회원
GCC-PEE-F21S1G4
5 회원들
안내서 5개 작성하였습니다
댓글 2개
Hi!! I have the same model of notebook with 64 giga emmc. Is it possible installing an ssd or an hdd?
Riccardo Insolera - 답글
I followed each and every step, and realised a little too late that my laptop is a HP ProBook x360 11 G1 -and not a G5. The G1 requires the ability to de-solder the built in charging port.
On step 6, I noticed there were 6 screws holding the battery in, not 4.
Then on step 9, I noticed that the charging port is actually soldered to the motherboard and there is no visible cable attaching it to the board which can be unhooked.
Sam T - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 19
전체 시간: 1,006
