주요 콘텐츠로 건너뛰기
HP ProBook x360 11 G5 EE Display Panel Replacement
필요한 것
  1. HP ProBook x360 11 G5 EE Display Panel Replacement, Keyboard Assembly: 1 단계, 이미지 3개 중 1개 HP ProBook x360 11 G5 EE Display Panel Replacement, Keyboard Assembly: 1 단계, 이미지 3개 중 2개 HP ProBook x360 11 G5 EE Display Panel Replacement, Keyboard Assembly: 1 단계, 이미지 3개 중 3개
    • Remove the 4.1 mm screws with a T5 Torx screwdriver.
    • Remove the 4.1 mm screws using a JIS #0 screwdriver.
  2. HP ProBook x360 11 G5 EE Display Panel Replacement: 2 단계, 이미지 1개 중 1개
    • Use an opening pick to pry the corners of the keyboard deck.
  3. HP ProBook x360 11 G5 EE Display Panel Replacement: 3 단계, 이미지 3개 중 1개 HP ProBook x360 11 G5 EE Display Panel Replacement: 3 단계, 이미지 3개 중 2개 HP ProBook x360 11 G5 EE Display Panel Replacement: 3 단계, 이미지 3개 중 3개
    • Use an opening pick or opening tool to pry around the sides of the keyboard assembly.
  4. HP ProBook x360 11 G5 EE Display Panel Replacement: 4 단계, 이미지 3개 중 1개 HP ProBook x360 11 G5 EE Display Panel Replacement: 4 단계, 이미지 3개 중 2개 HP ProBook x360 11 G5 EE Display Panel Replacement: 4 단계, 이미지 3개 중 3개
    • Lift the keyboard assembly to expose two ribbon cables.
    • Lift the two plastic tabs that hold the cables in place on the motherboard
    • Slide the ribbon cables out of each connector.
  5. HP ProBook x360 11 G5 EE Display Panel Replacement: 5 단계, 이미지 2개 중 1개 HP ProBook x360 11 G5 EE Display Panel Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the keyboard assembly from the rest of the computer.
  6. HP ProBook x360 11 G5 EE Display Panel Replacement, Battery: 6 단계, 이미지 2개 중 1개 HP ProBook x360 11 G5 EE Display Panel Replacement, Battery: 6 단계, 이미지 2개 중 2개
    • Remove the four 3 mm screws from the battery with the JIS #0 screwdriver.
  7. HP ProBook x360 11 G5 EE Display Panel Replacement: 7 단계, 이미지 3개 중 1개 HP ProBook x360 11 G5 EE Display Panel Replacement: 7 단계, 이미지 3개 중 2개 HP ProBook x360 11 G5 EE Display Panel Replacement: 7 단계, 이미지 3개 중 3개
    • Pry the battery up from the laptop using an opening pick.
    • Lift the battery out of its place.
  8. HP ProBook x360 11 G5 EE Display Panel Replacement, Display Panel: 8 단계, 이미지 3개 중 1개 HP ProBook x360 11 G5 EE Display Panel Replacement, Display Panel: 8 단계, 이미지 3개 중 2개 HP ProBook x360 11 G5 EE Display Panel Replacement, Display Panel: 8 단계, 이미지 3개 중 3개
    • Use the opening pick and metal spudger to pry open the display cover.
  9. HP ProBook x360 11 G5 EE Display Panel Replacement: 9 단계, 이미지 2개 중 1개 HP ProBook x360 11 G5 EE Display Panel Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the ribbon wire that is attached to the display cover to fully detach it.
  10. HP ProBook x360 11 G5 EE Display Panel Replacement: 10 단계, 이미지 2개 중 1개 HP ProBook x360 11 G5 EE Display Panel Replacement: 10 단계, 이미지 2개 중 2개
    • Remove the four 2.3 mm screws holding the screen in place with the JIS #0 screwdriver.
  11. HP ProBook x360 11 G5 EE Display Panel Replacement: 11 단계, 이미지 3개 중 1개 HP ProBook x360 11 G5 EE Display Panel Replacement: 11 단계, 이미지 3개 중 2개 HP ProBook x360 11 G5 EE Display Panel Replacement: 11 단계, 이미지 3개 중 3개
    • Lift the screen to disconnect the wire attaching it to the laptop.
    • Remove the display panel from the rest of the laptop.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Michelle Pina
회원 가입일: 10/26/21
506 평판
안내서 4개를 작성함
Gateway, Team 1-4, Pee Fall 2021 Gateway, Team 1-4, Pee Fall 2021 회원
GCC-PEE-F21S1G4
5 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 14
지난 30일: 51
전체 시간: 3,758
