주요 콘텐츠로 건너뛰기
HP Slate 7 4601 Battery Replacement
필요한 것
  1. HP Slate 7 4601 Battery Replacement, Battery: 1 단계, 이미지 1/2 HP Slate 7 4601 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Begin your replacement by using a T3 or T4 Torx screwdriver.
    • Remove the two 1.4mm x 3mm Torx Head screws at the top of the device.
  2. HP Slate 7 4601 Battery Replacement: 2 단계, 이미지 1/2 HP Slate 7 4601 Battery Replacement: 2 단계, 이미지 2/2
    • With the pointed end of the spudger, remove the thin metal band.
    • It is easiest to remove the metal band through the headphone opening.
  3. HP Slate 7 4601 Battery Replacement: 3 단계, 이미지 1/2 HP Slate 7 4601 Battery Replacement: 3 단계, 이미지 2/2
    • Using the flat end of the spudger, pry back the rear plastic cover.
    • As you work your way around the edge, several "pop" noises will be made. These noises are caused by the plastic clips coming undone.
  4. HP Slate 7 4601 Battery Replacement: 4 단계, 이미지 1/1
    • Remove the rear cover.
  5. HP Slate 7 4601 Battery Replacement: 5 단계, 이미지 1/1
    • Locate and remove the yellow tape covering the red and white speaker wires.
  6. HP Slate 7 4601 Battery Replacement: 6 단계, 이미지 1/2 HP Slate 7 4601 Battery Replacement: 6 단계, 이미지 2/2
    • Using the pointed end of the spudger, push both sides of the speaker wire connector out of its base.
    • Push the same amount on both sides of the connector to avoid jamming or twisting its metal pins.
    • Do not yank or pull on the speaker wires, since they are fragile. Only push on the white connector.
  7. HP Slate 7 4601 Battery Replacement: 7 단계, 이미지 1/1
    • Gently pull back the foil covering the gold charging port ribbon.
  8. HP Slate 7 4601 Battery Replacement: 8 단계, 이미지 1/2 HP Slate 7 4601 Battery Replacement: 8 단계, 이미지 2/2
    • Using the flat end of the spudger, lift up the black panel covering the charging port connector.
    • Gently slide the charging port ribbon out from its housing.
    • It may be easier to use the pointed end of the spudger than your fingers.
  9. HP Slate 7 4601 Battery Replacement: 9 단계, 이미지 1/1
    • Lift gold charging strip away from the battery.
  10. HP Slate 7 4601 Battery Replacement: 10 단계, 이미지 1/2 HP Slate 7 4601 Battery Replacement: 10 단계, 이미지 2/2
    • Push the white battery connector out of its housing using the pointed end of the spudger.
  11. HP Slate 7 4601 Battery Replacement: 11 단계, 이미지 1/1
    • Using the #00 Phillips Head screwdriver, remove the 5 screws holding the battery in place.
    • The four 1.75mm x 3mm silver Phillips Head screws circled in red are interchangeable.
    • The black 1.75mm x 4mm Phillips Head screw must go back to the same spot during reassembly.
  12. HP Slate 7 4601 Battery Replacement: 12 단계, 이미지 1/1
    • Lift battery out of its place and set aside.
결론
다른 18명이 해당 안내서를 완성하였습니다.
Zachary
회원 가입일: 04/14/14
1,453 평판
안내서 2개 작성하였습니다
Cal Poly, Team 13-30, Maness Spring 2014 Cal Poly, Team 13-30, Maness Spring 2014 회원
CPSU-MANESS-S14S13G30
3 회원들
안내서 8개 작성하였습니다
댓글 3개
Buenas tardes, como están? Consulta, la batería se puede reemplazar por otra genérica, existe algún repuesto?
Javier Sanchez - 답글
Thanx for this amazing demo steps. Sir i need battery of this tab, coz i cant find this battery anywhere then someone told me to go online purchase it wil you so i decided to go online n finally i found ur page so plz arrange me the battery of this tab. My HP Slate 7 battery is not charging . I m from pakistan n my email is aasifbrothers79@gmail.com. Sir i m looking forward for ur kind reply .Thanx
Regards, Asif Sultan
Asif Sultan - 답글
where do i buy the battery in india… there is a site Maxbhi, I ordered the battery, they never send the battery neither returned the money…
Kapil Baidya - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 11
전체 시간: 29,713
