주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Slate 7 4601 Front Screen Replacement
필요한 것
    1. HP Slate 7 4601 Front Screen Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP Slate 7 4601 Front Screen Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Begin your replacement by using a T3 or T4 Torx screwdriver.
      • Remove the two 1.4mm x 3mm Torx Head screws at the top of the device.
      댓글 쓰기
    2. HP Slate 7 4601 Front Screen Replacement: 2 단계, 이미지 2개 중 1개 HP Slate 7 4601 Front Screen Replacement: 2 단계, 이미지 2개 중 2개
      • With the pointed end of the spudger, remove the thin metal band.
      • It is easiest to remove the metal band through the headphone opening.
      댓글 쓰기
    3. HP Slate 7 4601 Front Screen Replacement: 3 단계, 이미지 2개 중 1개 HP Slate 7 4601 Front Screen Replacement: 3 단계, 이미지 2개 중 2개
      • Using the flat end of the spudger, pry back the rear plastic cover.
      • As you work your way around the edge, several "pop" noises will be made. These noises are caused by the plastic clips coming undone.
      댓글 쓰기
    4. HP Slate 7 4601 Front Screen Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the rear cover.
      댓글 쓰기
    5. HP Slate 7 4601 Front Screen Replacement: 5 단계, 이미지 1개 중 1개
      • Locate and remove the yellow tape covering the red and white speaker wires.
      댓글 쓰기
    6. HP Slate 7 4601 Front Screen Replacement: 6 단계, 이미지 2개 중 1개 HP Slate 7 4601 Front Screen Replacement: 6 단계, 이미지 2개 중 2개
      • Using the pointed end of the spudger, push both sides of the speaker wire connector out of its base.
      • Push the same amount on both sides of the connector to avoid jamming or twisting its metal pins.
      • Do not yank or pull on the speaker wires, since they are fragile. Only push on the white connector.
      댓글 쓰기
    7. HP Slate 7 4601 Front Screen Replacement: 7 단계, 이미지 1개 중 1개
      • Gently pull back the foil covering the gold charging port ribbon.
      댓글 쓰기
    8. HP Slate 7 4601 Front Screen Replacement: 8 단계, 이미지 2개 중 1개 HP Slate 7 4601 Front Screen Replacement: 8 단계, 이미지 2개 중 2개
      • Using the flat end of the spudger, lift up the black panel covering the charging port connector.
      • Gently slide the charging port ribbon out from its housing.
      • It may be easier to use the pointed end of the spudger than your fingers.
      댓글 쓰기
    9. HP Slate 7 4601 Front Screen Replacement: 9 단계, 이미지 1개 중 1개
      • Lift gold charging strip away from the battery.
      댓글 쓰기
    10. HP Slate 7 4601 Front Screen Replacement: 10 단계, 이미지 2개 중 1개 HP Slate 7 4601 Front Screen Replacement: 10 단계, 이미지 2개 중 2개
      • Push the white battery connector out of its housing using the pointed end of the spudger.
      댓글 쓰기
    11. HP Slate 7 4601 Front Screen Replacement: 11 단계, 이미지 1개 중 1개
      • Using the #00 Phillips Head screwdriver, remove the 5 screws holding the battery in place.
      • The four 1.75mm x 3mm silver Phillips Head screws circled in red are interchangeable.
      • The black 1.75mm x 4mm Phillips Head screw must go back to the same spot during reassembly.
      댓글 쓰기
    12. HP Slate 7 4601 Front Screen Replacement: 12 단계, 이미지 1개 중 1개
      • Lift battery out of its place and set aside.
      댓글 쓰기
    1. HP Slate 7 4601 Front Screen Replacement, Charging Port: 13 단계, 이미지 2개 중 1개 HP Slate 7 4601 Front Screen Replacement, Charging Port: 13 단계, 이미지 2개 중 2개
      • To free the speaker assembly, you will need a #00 Phillips Head screwdriver.
      • Remove the two 1.75mm x 3mm Phillips Head screws from the speaker assembly.
      댓글 쓰기
    2. HP Slate 7 4601 Front Screen Replacement: 14 단계, 이미지 2개 중 1개 HP Slate 7 4601 Front Screen Replacement: 14 단계, 이미지 2개 중 2개
      • Pull back the foil overlapping the charging port to reveal another 1.75mm x 3mm Phillips Head screw.
      • Remove the screw with a #00 Phillips Head screwdriver.
      댓글 쓰기
    3. HP Slate 7 4601 Front Screen Replacement: 15 단계, 이미지 1개 중 1개
      • Lift the charging port and set it aside.
      댓글 쓰기
    1. HP Slate 7 4601 Front Screen Replacement, Speaker: 16 단계, 이미지 1개 중 1개
      • Lift the two speakers out of the device and set them aside.
      댓글 쓰기
    1. HP Slate 7 4601 Front Screen Replacement, Motherboard: 17 단계, 이미지 2개 중 1개 HP Slate 7 4601 Front Screen Replacement, Motherboard: 17 단계, 이미지 2개 중 2개
      • Disconnect the LCD screen ribbon by lifting up the black panel with the flat end of a spudger and sliding the gold strip out.
      • When reconnecting the LCD connector ribbon, make sure that it's pushed in all the way. If it isn't, there will be horizontal lines when you power the tablet on.
      댓글 쓰기
    2. HP Slate 7 4601 Front Screen Replacement: 18 단계, 이미지 2개 중 1개 HP Slate 7 4601 Front Screen Replacement: 18 단계, 이미지 2개 중 2개
      • Likewise, disconnect the square radio chip ribbon by lifting up the black panel with a spudger and sliding the gold strip out.
      댓글 쓰기
    3. HP Slate 7 4601 Front Screen Replacement: 19 단계, 이미지 2개 중 1개 HP Slate 7 4601 Front Screen Replacement: 19 단계, 이미지 2개 중 2개
      • You will be using a #00 Phillips Head screwdriver to free the motherboard.
      • Remove the six 1.75mm x 3mm Phillips Head screws holding the motherboard to the screen.
      댓글 쓰기
    4. HP Slate 7 4601 Front Screen Replacement: 20 단계, 이미지 2개 중 1개 HP Slate 7 4601 Front Screen Replacement: 20 단계, 이미지 2개 중 2개
      • Using your hand, lift up the silver tape from the copper plate.
      • Lift the motherboard out of the device.
      • You may need to wiggle and work the motherboard to get it released from the device
      댓글 쓰기
    1. HP Slate 7 4601 Front Screen Replacement, Front Screen / Volume Buttons: 21 단계, 이미지 1개 중 1개
      • Remove the metal band surrounding the device by lifting it up out of the placement pins. Begin at one end and work your way around.
      댓글 쓰기
    2. HP Slate 7 4601 Front Screen Replacement: 22 단계, 이미지 1개 중 1개
      • You now have access to the LCD screen.
      • You can replace the volume rocker by lifting it up and out of the device.
      • The volume rocker should be reinserted so the "up" button is toward the top of the tablet during reassembly.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 14명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Ryan ONeill
회원 가입일: 04/11/14
2,130 평판
안내서 1개를 작성함
Cal Poly, Team 13-30, Maness Spring 2014 Cal Poly, Team 13-30, Maness Spring 2014 회원
CPSU-MANESS-S14S13G30
3 회원들
안내서 24개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 7
지난 30일: 47
전체 시간: 23,884
