주요 콘텐츠로 건너뛰기
HP Slate 7 Extreme 4400US Battery Replacement
필요한 것
  1. HP Slate 7 Extreme 4400US Battery Replacement, Back Cover: 1 단계, 이미지 1/3 HP Slate 7 Extreme 4400US Battery Replacement, Back Cover: 1 단계, 이미지 2/3 HP Slate 7 Extreme 4400US Battery Replacement, Back Cover: 1 단계, 이미지 3/3
    • Use the plastic opening tool to separate the back cover from the tablet. Carefully use the tool to pry open the sides, going around the entire tablet to lift the sides up.
    • Once all sides have been pried up, pull the cover off and place it to the side.
  2. HP Slate 7 Extreme 4400US Battery Replacement, Battery: 2 단계, 이미지 1/3 HP Slate 7 Extreme 4400US Battery Replacement, Battery: 2 단계, 이미지 2/3 HP Slate 7 Extreme 4400US Battery Replacement, Battery: 2 단계, 이미지 3/3
    • Cut the battery connectors one by one using wire cutters.
    • Do not cut all the wires at the same time; you risk blowing up the battery or destroying the motherboard!
    • After disconnecting the battery, take the new battery and use wire connectors to connect to the motherboard.
    • You may use a soldering tool to disconnect the wires from the motherboard, and to also soldering the wires for the replacement battery onto the motherboard.
결론
Brandon Ko
회원 가입일: 09/15/16
698 평판
안내서 6개 작성하였습니다
USF Tampa, Team 11-4, Blackwell Fall 2016 USF Tampa, Team 11-4, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S11G4
4 회원들
안내서 16개 작성하였습니다
댓글 한 개
Dude, do you have this part? HP Slate 7 Extreme 4400CA
https://www.worthpoint.com/worthopedia/o...
sivaldodomingos - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 11
전체 시간: 1,131
