주요 콘텐츠로 건너뛰기
HP Slate 7 Extreme 4400US Bottom Speaker Replacement
필요한 것
  1. HP Slate 7 Extreme 4400US Bottom Speaker Replacement, Back Cover: 1 단계, 이미지 1/3 HP Slate 7 Extreme 4400US Bottom Speaker Replacement, Back Cover: 1 단계, 이미지 2/3 HP Slate 7 Extreme 4400US Bottom Speaker Replacement, Back Cover: 1 단계, 이미지 3/3
    • Use the plastic opening tool to separate the back cover from the tablet. Carefully use the tool to pry open the sides, going around the entire tablet to lift the sides up.
    • Once all sides have been pried up, pull the cover off and place it to the side.
  2. HP Slate 7 Extreme 4400US Bottom Speaker Replacement, Bottom Speaker: 2 단계, 이미지 1/2 HP Slate 7 Extreme 4400US Bottom Speaker Replacement, Bottom Speaker: 2 단계, 이미지 2/2
    • Locate the wires connecting the bottom speaker to the motherboard. The wires will be running alongside the battery
    • Using the PH #000 screw bit, unscrew the two 5.0 mm screws holding the bottom speaker in place
  3. HP Slate 7 Extreme 4400US Bottom Speaker Replacement: 3 단계, 이미지 1/3 HP Slate 7 Extreme 4400US Bottom Speaker Replacement: 3 단계, 이미지 2/3 HP Slate 7 Extreme 4400US Bottom Speaker Replacement: 3 단계, 이미지 3/3
    • Locate where the speakers' wires are connected to the motherboard.
    • Using a pair of wire cutters, cut the wires connecting the speaker to the motherboard. Use a wire stripper to expose the wire to connect it with the wires of the new speaker.
    • You can also use a soldering tool to disconnect the wires from the motherboard and then connect the wires of the new speaker using the soldering tool.
결론
Brandon Ko
회원 가입일: 09/15/16
698 평판
안내서 6개 작성하였습니다
USF Tampa, Team 11-4, Blackwell Fall 2016 USF Tampa, Team 11-4, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S11G4
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 133
