주요 콘텐츠로 건너뛰기
HP Slate 7 Extreme 4400US Front-facing Camera Replacement
필요한 것
  1. HP Slate 7 Extreme 4400US Front-facing Camera Replacement, Back Cover: 1 단계, 이미지 1/3 HP Slate 7 Extreme 4400US Front-facing Camera Replacement, Back Cover: 1 단계, 이미지 2/3 HP Slate 7 Extreme 4400US Front-facing Camera Replacement, Back Cover: 1 단계, 이미지 3/3
    • Use the plastic opening tool to separate the back cover from the tablet. Carefully use the tool to pry open the sides, going around the entire tablet to lift the sides up.
    • Once all sides have been pried up, pull the cover off and place it to the side.
  2. HP Slate 7 Extreme 4400US Front-facing Camera Replacement, Front-facing Camera: 2 단계, 이미지 1/2 HP Slate 7 Extreme 4400US Front-facing Camera Replacement, Front-facing Camera: 2 단계, 이미지 2/2
    • Use the PH #000 screw bit to remove the 5.0 mm screw holding down the top speaker to expose the front-facing camera.
  3. HP Slate 7 Extreme 4400US Front-facing Camera Replacement: 3 단계, 이미지 1/3 HP Slate 7 Extreme 4400US Front-facing Camera Replacement: 3 단계, 이미지 2/3 HP Slate 7 Extreme 4400US Front-facing Camera Replacement: 3 단계, 이미지 3/3
    • Pull back the tape holding the the front facing camera's connector strip to the device.
    • Use the nylon spudger to flip up the black retaining flap of the zero insertion force (ZIF) connector holding the strip in place.
    • Gently pull the camera's connecting strip out from the port.
결론
Brandon Ko
회원 가입일: 09/15/16
698 평판
안내서 6개 작성하였습니다
USF Tampa, Team 11-4, Blackwell Fall 2016 USF Tampa, Team 11-4, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S11G4
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 158
