필요한 것
Use the plastic opening tool to separate the back cover from the tablet. Carefully use the tool to pry open the sides, going around the entire tablet to lift the sides up.
Once all sides have been pried up, pull the cover off and place it to the side.
Use the PH #000 screw bit to remove the 5.0 mm screw holding down the top speaker to expose the front-facing camera.
거의 끝나갑니다!
결론
