주요 콘텐츠로 건너뛰기
HP Slate 7 Extreme 4400US Rear-Facing Camera Replacement
필요한 것
  1. HP Slate 7 Extreme 4400US Rear-Facing Camera Replacement, Back Cover: 1 단계, 이미지 1/3 HP Slate 7 Extreme 4400US Rear-Facing Camera Replacement, Back Cover: 1 단계, 이미지 2/3 HP Slate 7 Extreme 4400US Rear-Facing Camera Replacement, Back Cover: 1 단계, 이미지 3/3
    • Use the plastic opening tool to separate the back cover from the tablet. Carefully use the tool to pry open the sides, going around the entire tablet to lift the sides up.
    • Once all sides have been pried up, pull the cover off and place it to the side.
  2. HP Slate 7 Extreme 4400US Rear-Facing Camera Replacement, Rear-Facing Camera: 2 단계, 이미지 1/3 HP Slate 7 Extreme 4400US Rear-Facing Camera Replacement, Rear-Facing Camera: 2 단계, 이미지 2/3 HP Slate 7 Extreme 4400US Rear-Facing Camera Replacement, Rear-Facing Camera: 2 단계, 이미지 3/3
    • Pull back the tape holding the the camera's connector strip to the device.
    • Use the nylon spudger to flip up the black retaining flap of the zero insertion force (ZIF) connector holding the strip in place.
    • Gently pull the camera's connecting strip out from the port.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Riley Wells
회원 가입일: 09/15/16
111 평판
안내서 1개 작성함
USF Tampa, Team 11-4, Blackwell Fall 2016 USF Tampa, Team 11-4, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S11G4
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 176
