주요 콘텐츠로 건너뛰기
HP Slate 7 Extreme 4400US Top Speaker Replacement
필요한 것
  1. HP Slate 7 Extreme 4400US Top Speaker Replacement, Back Cover: 1 단계, 이미지 1/3 HP Slate 7 Extreme 4400US Top Speaker Replacement, Back Cover: 1 단계, 이미지 2/3 HP Slate 7 Extreme 4400US Top Speaker Replacement, Back Cover: 1 단계, 이미지 3/3
    • Use the plastic opening tool to separate the back cover from the tablet. Carefully use the tool to pry open the sides, going around the entire tablet to lift the sides up.
    • Once all sides have been pried up, pull the cover off and place it to the side.
  2. HP Slate 7 Extreme 4400US Top Speaker Replacement, Top Speaker: 2 단계, 이미지 1/2 HP Slate 7 Extreme 4400US Top Speaker Replacement, Top Speaker: 2 단계, 이미지 2/2
    • Use the PH #000 phillips screw bit to remove one 5.0 mm screw.
  3. HP Slate 7 Extreme 4400US Top Speaker Replacement: 3 단계, 이미지 1/3 HP Slate 7 Extreme 4400US Top Speaker Replacement: 3 단계, 이미지 2/3 HP Slate 7 Extreme 4400US Top Speaker Replacement: 3 단계, 이미지 3/3
    • Gently pull the entire black housing away from device.
    • Locate where the speakers' wires are connected to the motherboard.
    • Using wire cutters, sever the wires connecting the speaker to the motherboard. Strip the wires with a wire stripper and fashion the new wires to the old ones connected to the motherboard to reconnect.
    • You may use a soldering tool to disconnect the wires from the motherboard and to reconnect the new wires back to the motherboard.
결론
Brandon Ko
회원 가입일: 09/15/16
698 평판
안내서 6개 작성하였습니다
USF Tampa, Team 11-4, Blackwell Fall 2016 USF Tampa, Team 11-4, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S11G4
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 7
전체 시간: 149
