이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Begin your replacement by using a T3 or T4 Torx screwdriver.
Remove the two 1.4mm x 3mm Torx Head screws at the top of the device.
Locate and remove the yellow tape covering the red and white speaker wires.
Using the pointed end of the spudger, push both sides of the speaker wire connector out of its base.
Using the flat end of the spudger, lift up the black panel covering the charging port connector.
Gently slide the charging port ribbon out from its housing.
Push the white battery connector out of its housing using the pointed end of the spudger.
Using the #00 Phillips Head screwdriver, remove the 5 screws holding the battery in place.
The four 1.75mm x 3mm silver Phillips Head screws circled in red are interchangeable.
The black 1.75mm x 4mm Phillips Head screw must go back to the same spot during reassembly.
다른 18명이 해당 안내서를 완성하였습니다.
댓글 3개
Buenas tardes, como están? Consulta, la batería se puede reemplazar por otra genérica, existe algún repuesto?
Thanx for this amazing demo steps. Sir i need battery of this tab, coz i cant find this battery anywhere then someone told me to go online purchase it wil you so i decided to go online n finally i found ur page so plz arrange me the battery of this tab. My HP Slate 7 battery is not charging . I m from pakistan n my email is aasifbrothers79@gmail.com. Sir i m looking forward for ur kind reply .Thanx
Regards, Asif Sultan
where do i buy the battery in india… there is a site Maxbhi, I ordered the battery, they never send the battery neither returned the money…
