주요 콘텐츠로 건너뛰기
HP Slate 8 Pro Motherboard Replacement
필요한 것
  1. HP Slate 8 Pro Motherboard Replacement, Remove Back Panel: 1 단계, 이미지 2개 중 1개 HP Slate 8 Pro Motherboard Replacement, Remove Back Panel: 1 단계, 이미지 2개 중 2개
    • Secure the suction cup to the center of the device’s screen.
    • Begin to pull upwards with the suction cup. While pulling, start easing the plastic opening tool into the space between the screen and the device. This will gradually separate the screen from the plastic back panel.
  2. HP Slate 8 Pro Motherboard Replacement, Remove yellow cables: 2 단계, 이미지 2개 중 1개 HP Slate 8 Pro Motherboard Replacement, Remove yellow cables: 2 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a spudger tool to release the black clips on the two connectors holding the flat, yellow cable in place.
    • Use the tweezers to pull the flat, yellow cable out of its connectors.
    • Use the tweezers to disconnect the battery connector from the circuit board.
    • Using the spudger tool again, pry up and release the connectors at the ends of the flat, orange cable.
    • Remove the flat, orange cable.
  3. HP Slate 8 Pro Motherboard Replacement, Remove Screws Around Battery: 3 단계, 이미지 1개 중 1개
    • As shown, the battery is held in place by a total of 8 screws. Use the #00 Phillips screwdriver to remove all 8.
  4. HP Slate 8 Pro Motherboard Replacement, Lift Battery out of Device: 4 단계, 이미지 1개 중 1개
    • Grasp the battery and remove it from the device.
    • Do not attempt to open or tamper with the battery. This could result in injury.
  5. HP Slate 8 Pro Motherboard Replacement, Motherboard: 5 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Disconnect the five connectors.
    • With the zero insertion force connectors, be sure to flip up the tab to avoid damaging the connector.
    • Use tweezers to disconnect the three antenna connectors
  6. HP Slate 8 Pro Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the four PH#00 2.4mm screws that hold in the motherboard in place.
  7. HP Slate 8 Pro Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Use tweezers and a spudger to remove the motherboard.
    • You may have to use a spudger to scrape off the adhesive holding the motherboard in place.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Andrew Hall
회원 가입일: 05/23/16
322 평판
안내서 3개를 작성함
IUPUI, Team 1-4, Renguette SU 2016 IUPUI, Team 1-4, Renguette SU 2016 회원
IUPUI-RENGUETTE-SU16S1G4
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 628
