주요 콘텐츠로 건너뛰기
HP Slate 8 Pro Speakers Replacement
필요한 것
  1. HP Slate 8 Pro Speakers Replacement, Remove back cover: 1 단계, 이미지 1/1
    • Use plastic opening tool to pry back panel off.
  2. HP Slate 8 Pro Speakers Replacement, Detach IO Board from system: 2 단계, 이미지 1/2 HP Slate 8 Pro Speakers Replacement, Detach IO Board from system: 2 단계, 이미지 2/2
    • Remove the orange and yellow ribbon cables.
    • detach the screws along the IO board
  3. HP Slate 8 Pro Speakers Replacement, Remove the IO board and the speakers: 3 단계, 이미지 1/1
    • Remove the IO board and the speakers circuit. Note that they are held together.
  4. HP Slate 8 Pro Speakers Replacement, Detach the speakers from the IO board.: 4 단계, 이미지 1/1
    • The tablet has two speakers. Each speaker is located to both sides of the IO board.
    • Detach the speakers from the cables that connect the speakers and the IO board. You will find more details in step 5 and 6.
  5. HP Slate 8 Pro Speakers Replacement, Remove the wires of the speakers from the IO board.: 5 단계, 이미지 1/1
    • To remove the cables that connect the speakers and the IO board, apply a subtle pressure to pull the cable out.
  6. HP Slate 8 Pro Speakers Replacement, Replace your speakers with the new parts: 6 단계, 이미지 1/2 HP Slate 8 Pro Speakers Replacement, Replace your speakers with the new parts: 6 단계, 이미지 2/2
    • Once you detach the speakers from the IO board, you should have three pieces as shown.
    • You are ready to replace the speakers.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jose Revelo
회원 가입일: 09/23/14
305 평판
안내서 3개 작성하였습니다
USF Tampa, Team 9-4, Blackwell Fall 2014 USF Tampa, Team 9-4, Blackwell Fall 2014 회원
USFT-BLACKWELL-F14S9G4
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 432
