주요 콘텐츠로 건너뛰기
HP Spectre x360 13-ac023dx Battery Replacement
필요한 것
  1. HP Spectre  x360 13-ac023dx Battery Replacement, Battery: 1 단계, 이미지 1/2 HP Spectre  x360 13-ac023dx Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Flip the laptop over so the model sticker faces the ceiling.
  2. HP Spectre  x360 13-ac023dx Battery Replacement: 2 단계, 이미지 1/3 HP Spectre  x360 13-ac023dx Battery Replacement: 2 단계, 이미지 2/3 HP Spectre  x360 13-ac023dx Battery Replacement: 2 단계, 이미지 3/3
    • Use a Torx #5 screwdriver to remove the six 3.5 mm screws holding the back cover to the laptop.
  3. HP Spectre  x360 13-ac023dx Battery Replacement: 3 단계, 이미지 1/2 HP Spectre  x360 13-ac023dx Battery Replacement: 3 단계, 이미지 2/2
    • Use the Phillips #000 screwdriver to remove the four 3.5 mm screws holding the battery.
    • After removing the screws, detach the battery wire from the mother board with the iFixit opening tool.
    • Then, carefully lift the battery off with the iFixit opening tool.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Dylan Beery
회원 가입일: 10/21/19
290 평판
안내서 1개 작성함
UMass Dartmouth, Team S1-G6, Botvin Fall 2019 UMass Dartmouth, Team S1-G6, Botvin Fall 2019 회원
UMASSD-BOTVIN-F19S1G6
3 회원들
안내서 6개 작성하였습니다
댓글 4개
The overall procedure is ok, however as others commented instructions on how to remove the feet would be helpful. I tried a heat gun to help loosen the glue, however that just melted the feat. Overall go the job done, but 2 out of the 4 feet were destroyed in the process.
Also in my case there were no screws under the top or bottom feet, so I could have probably removed the cover without removing the feet.
Joseph Ficara - 답글
I think HP quietly refreshed the internals of this laptop or something, because despite appearing externally identical to the laptop shown in the pictures, mine has a smaller main board and differently sized battery. so you should open yours up and check before ordering the battery. mine has the PK03XL. this is double annoying because I was repairing this one for a friend, and she's the one who ordered the battery.
csd - 답글
just finished my repair of my w-013 version. good to know that the top two feet have screws underneath them - small risk of denting the bottom cover if you're not gentle. also, the cable is slightly too long to fit neatly in the battery receptacle - it required some jamming that i'll probably be concerned about for a while.
pkim - 답글
This guide was helpful but my bottom two feet didn't have screws. I used a T4 instead of T5 and for the Phillips a T0 and a T1.
The battery had two metal stickers on it under the bottom feet so I put them on the replacement battery in the same place.
My model is 13-ac033dx
Oliver Hansen - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 36
30일 전: 127
전체 시간: 8,994
