주요 콘텐츠로 건너뛰기
HP Spectre 13 4003dx x360 Battery Replacement
필요한 것
  1. HP Spectre 13 4003dx x360 Battery Replacement, Battery: 1 단계, 이미지 1/2 HP Spectre 13 4003dx x360 Battery Replacement, Battery: 1 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    구매
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Turn the computer upside down.
    • Use the T5 Torx Screwdriver to remove the eight 3.3 mm screws.
    • Make sure to use the magnetic project mat to help you keep track of the small screws.
  2. HP Spectre 13 4003dx x360 Battery Replacement: 2 단계, 이미지 1/2 HP Spectre 13 4003dx x360 Battery Replacement: 2 단계, 이미지 2/2
    • Use an opening tool to pry up and loosen the back case from the laptop.
    • If the back case doesn't loosen easily, there may be screws hidden underneath the rubber feet. Carefully pry a foot up and remove any hidden screws.
    • Remove the back case.
  3. HP Spectre 13 4003dx x360 Battery Replacement: 3 단계, 이미지 1/2 HP Spectre 13 4003dx x360 Battery Replacement: 3 단계, 이미지 2/2
    • Remove the four 2mm Phillips #00 screws securing the battery.
    • The screw locations are marked by small white arrows on the battery.
  4. HP Spectre 13 4003dx x360 Battery Replacement: 4 단계, 이미지 1/3 HP Spectre 13 4003dx x360 Battery Replacement: 4 단계, 이미지 2/3 HP Spectre 13 4003dx x360 Battery Replacement: 4 단계, 이미지 3/3
    • Peel off the adhesive on the left side of the battery holding the speaker wire down.
    • Move the battery slightly to gain access to the battery plug, located on the left edge of the battery.
    • Carefully unplug the battery by pulling the connector towards the battery.
    • Pull parallel to the battery, not straight up.
    • Remove the battery.
    • It is normal for your battery to flex and bend a bit where the wider section meets the narrower section.
결론
For optimal performance, after completing this guide, calibrate your newly installed battery.
다른 7명이 해당 안내서를 완성하였습니다.
Alie Antar
회원 가입일: 01/29/18
661 평판
안내서 2개 작성하였습니다
USF Tampa, Team S5-G4, Passmore Spring 2018 USF Tampa, Team S5-G4, Passmore Spring 2018 회원
USFT-PASSMORE-S18S5G4
3 회원들
안내서 8개 작성하였습니다
댓글 5개
I have five T4 screws that came out without issue and three that refuse to budge. Now I am trying to figure out how to remove those without damaging the laptop itself.
fxb - 답글
Thank you! iFixit repair kit made getting the screws out easy. Now have a renewed laptop ready with 6 plus hours of battery life.
Nicholas Steblay - 답글
Tutoriel parfait, excepté peut-être qu’un double-fil côté droit de la batterie doit être libéré avant de sortir la batterie.
Bravo et merci, ça m’a tout simplement permis de me dépanner seul.
FirstName LastName - 답글
The official HP Manual (http://h10032.www1.hp.com/ctg/Manual/c04...) mentions using Torx T5 to remove the bottom cover.
Gitesh Agarwal - 답글
Thanks! I will correct the step with the right screw size.
Arthur Shi -
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 46
30일 전: 204
전체 시간: 22,657
