주요 콘텐츠로 건너뛰기
HP Spectre 13 4003dx x360 Display Assembly Replacement
필요한 것
  1. HP Spectre 13 4003dx x360 Display Assembly Replacement, Battery: 1 단계, 이미지 1/2 HP Spectre 13 4003dx x360 Display Assembly Replacement, Battery: 1 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    구매
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Turn the computer upside down.
    • Use the T5 Torx Screwdriver to remove the eight 3.3 mm screws.
    • Make sure to use the magnetic project mat to help you keep track of the small screws.
  2. HP Spectre 13 4003dx x360 Display Assembly Replacement: 2 단계, 이미지 1/2 HP Spectre 13 4003dx x360 Display Assembly Replacement: 2 단계, 이미지 2/2
    • Use an opening tool to pry up and loosen the back case from the laptop.
    • If the back case doesn't loosen easily, there may be screws hidden underneath the rubber feet. Carefully pry a foot up and remove any hidden screws.
    • Remove the back case.
  3. HP Spectre 13 4003dx x360 Display Assembly Replacement: 3 단계, 이미지 1/2 HP Spectre 13 4003dx x360 Display Assembly Replacement: 3 단계, 이미지 2/2
    • Remove the four 2mm Phillips #00 screws securing the battery.
    • The screw locations are marked by small white arrows on the battery.
  4. HP Spectre 13 4003dx x360 Display Assembly Replacement: 4 단계, 이미지 1/3 HP Spectre 13 4003dx x360 Display Assembly Replacement: 4 단계, 이미지 2/3 HP Spectre 13 4003dx x360 Display Assembly Replacement: 4 단계, 이미지 3/3
    • Peel off the adhesive on the left side of the battery holding the speaker wire down.
    • Move the battery slightly to gain access to the battery plug, located on the left edge of the battery.
    • Carefully unplug the battery by pulling the connector towards the battery.
    • Pull parallel to the battery, not straight up.
    • Remove the battery.
    • It is normal for your battery to flex and bend a bit where the wider section meets the narrower section.
  5. HP Spectre 13 4003dx x360 Display Assembly Replacement, Display Assembly: 5 단계, 이미지 1/3 HP Spectre 13 4003dx x360 Display Assembly Replacement, Display Assembly: 5 단계, 이미지 2/3 HP Spectre 13 4003dx x360 Display Assembly Replacement, Display Assembly: 5 단계, 이미지 3/3
    • Remove the two 2mm Phillips #00 screws from the fan.
    • Disconnect the fan from the motherboard.
  6. HP Spectre 13 4003dx x360 Display Assembly Replacement: 6 단계, 이미지 1/3 HP Spectre 13 4003dx x360 Display Assembly Replacement: 6 단계, 이미지 2/3 HP Spectre 13 4003dx x360 Display Assembly Replacement: 6 단계, 이미지 3/3
    • Using minimal force, disconnect both WiFi antennae cables.
    • Remove the single Phillips #00 screw that secures the WiFi card.
    • Slide the WiFi card up until it is completely removed.
    • Do not pull up on the wireless module while it is still seated. You may inadvertently damage it.
  7. HP Spectre 13 4003dx x360 Display Assembly Replacement: 7 단계, 이미지 1/2 HP Spectre 13 4003dx x360 Display Assembly Replacement: 7 단계, 이미지 2/2
    • Remove the four hinge screw with a Phillips #00 screwdriver.
  8. HP Spectre 13 4003dx x360 Display Assembly Replacement: 8 단계, 이미지 1/2 HP Spectre 13 4003dx x360 Display Assembly Replacement: 8 단계, 이미지 2/2
    • Grip the black tape and pull up to unplug.
  9. HP Spectre 13 4003dx x360 Display Assembly Replacement: 9 단계, 이미지 1/1
    • Separate the display assembly from the body of the computer.
    • As a result of the orientation of the hinges, you may need to rotate open the laptop to around 270 degrees to clear them.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Ethan Plumer
회원 가입일: 01/29/18
605 평판
안내서 2개 작성하였습니다
USF Tampa, Team S5-G4, Passmore Spring 2018 USF Tampa, Team S5-G4, Passmore Spring 2018 회원
USFT-PASSMORE-S18S5G4
3 회원들
안내서 8개 작성하였습니다
댓글 2개
You forgot to mention that some people may have to remove the heatsink like I did before the screen will come off.
Wargaming Super Noob - 답글
Anyone have any tips on reconnecting the WIFI antennas? I finally gave up and just decided to get a USB dongle… worked out well otherwise. I did also have to remove the heatsink like Wargaming Super Noob mentioned.
David Bergeron - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 14
30일 전: 57
전체 시간: 9,771
